MarkTF wrote:One would need the bill of material to know for certain, but the large value chip capacitors on the board are probably tantalum. The low value capacitors (>~ 1 uF) are almost certainly ceramic. I have no special insight into the Pi, but this is standard practice.
It used to be, but larger ceramics (10uF and more) have got competitive in logic-voltage (<=5V) applications recently and with modern high-speed switching converters there is less need for "bulk capacitance" than there used to be.
You can often guess the type of capacitor from the physical appearance. Ceramics are usually tan-colored (the exact shade varies), have contacts in the form of end-caps and have no markings to identify their value. Tantalums are usually found in yellow or black plastic cases with marking on them identifying their values and contacts on the bottom only. I have occasionally seen a tant in a package with end caps and no markings but it was still bright yellow.
I don't have any inside information but my reckoning is that all the capacitors on the Pi3 are ceramics.
