Ok I have figured some (but not all) of this myself.
I have hopefully enabled Lora 0 on both boards and commented out Lora 1.
I have the frequency for Lora 0 set to 434.500 and my PITS to 434.250.
I have an antenna connected to the Lora antenna connector on both the transmitter and the receiver.
When I run lora gateway on the receiving end attached to my Pi 3 Channel 0 (LH side) is populated in the terminal window with info such as Channel 0 434.5000MHz etc but it is not receiving anything? Telem pkts and image pkts = 0. The receiving Lora Pi is NOT yet connected to the internet so curl is failing.
RASPBERRY PI-IN-THE-SKY FLIGHT COMPUTER
RPi Hardware : BCM2708
RPi Revision : 900092
RPi Zero
PITS+ Board
Device Tree is disabled
RTTY Payload ID = 'CAEN_CP1'
Radio baud rate = 300
GPS Logging enabled
Telemetry Logging enabled
Camera (USB - fswebcam) Enabled
Adding custom camera parameters '' to raspistill calls
Image size changes at 2000m
RTTY Low image size 320 x 240 pixels
RTTY High image size 640 x 480 pixels
RTTY: 1 Telemetry packet every 4 image packets
RTTY: 60 seconds between photographs
Full Low image size 640 x 480 pixels
Full High image size 2592 x 1944 pixels
Full size: 60 seconds between photographs
GPS Power Saving = OFF
Switching GPS to flight mode above 1000 metres
LORA0 frequency set to 434.500
LORA0 Payload ID = 'CAEN_LORA_SKY'
LORA0 SSDV mode
LORA0 DIO0=6 DIO5=5
LORA0 Low image size 640 x 480 pixels
LORA0 High image size 1280 x 960 pixels
LORA0: 1 Telemetry packet every 20 image packets
LORA0: 30 seconds between photographs
LORA0 cycle time 15
LORA0 Slot 2
LORA0 Repeat Slot 6
LORA0 Uplink Slot 10
LORA0 Set To ASCII
LORA0 power set to 88h
LoRa channel 0 will Tx on calling frequency 434.475 every 20 packets
Frequency 434.250
MTX2 Frequency to be set to 434.2500MHz
MTX2 command is @PRG_410E76A0
Frequency 434.250
V2.4 or later board with I2C ADC
Interface eth0 has IP Address: 192.168.1.111
Channel 0 DIO0=6 DIO5=5
Setting LoRa Mode
Channel 0 frequency 434.500000 FrequencyValue = 6CA000h
Mode = 0
SDA/SCL = 2/3
Found file /home/pi/pits/tracker/images/RTTY/22_25_13.jpg to convert
Listening on channel 0
Setting flight mode
Free SD space = 27984.8MB
Free SD space = 27984.7MB
File ssdv_done_0 found
File ssdv_0_1.bin opened
>>>> Switching to SSDV file ssdv_0_1.bin
RTTY: SSDV record 0 of 32
RTTY: $$CAEN_CP1,1,00:00:00,0.00000,0.00000,00000,0,0,0,25.9,0.0,0*68C0
RTTY: SSDV record 1 of 32
RTTY: $$CAEN_CP1,2,00:00:00,0.00000,0.00000,00000,0,0,0,25.9,0.0,0*BF4D
RTTY: SSDV record 2 of 32
RTTY: $$CAEN_CP1,3,00:00:00,0.00000,0.00000,00000,0,0,0,25.9,0.0,0*0229
RTTY: SSDV record 3 of 32
RTTY: $$CAEN_CP1,4,00:00:00,0.00000,0.00000,00000,0,0,0,25.9,0.0,0*0076
RTTY: SSDV record 4 of 32
RTTY: $$CAEN_CP1,5,00:00:00,0.00000,0.00000,00000,0,0,0,25.9,0.0,0*BD12
RTTY: SSDV record 5 of 32
RTTY: $$CAEN_CP1,6,00:00:00,0.00000,0.00000,00000,0,0,0,25.9,0.0,0*6A9F
RTTY: SSDV record 6 of 32
RTTY: $$CAEN_CP1,7,00:00:00,0.00000,0.00000,00000,0,0,0,25.9,0.0,0*D7FB
RTTY: SSDV record 7 of 32
RTTY: $$CAEN_CP1,8,00:00:00,0.00000,0.00000,00000,0,0,0,25.9,0.0,0*6E21
RTTY: SSDV record 8 of 32
RTTY: $$CAEN_CP1,9,00:00:00,0.00000,0.00000,00000,0,0,0,25.8,0.0,0*6B24
RTTY: SSDV record 9 of 32
RTTY: $$CAEN_CP1,10,00:00:00,0.00000,0.00000,00000,0,0,0,25.8,0.0,0*8235
RTTY: SSDV record 10 of 32
