dgordon42
Re: Pi 3 Serial Issues
Tue May 15, 2018 9:53 pm
@marciokoko,
Nice try, but no.
The Pi uses one of it's serial ports to communicate with the Bluetooth Controller chip. It sends and receives low level data and instructions to/from the chip. Unfortunately, you can't just fire data at the chip and expect it to communicate it to another device over Bluetooth.
It should be possible to establish a connection over Bluetooth to another device using the Linux Bluetooth software on the Pi, but it is something I have never done. Perhaps someone with Bluetooth knowledge (Douglas6?) might be able to show you how.
Dave.
Douglas6
Tue May 15, 2018 10:08 pm
Dgordon42, thanks for all your help. I'm working with marciokoko in another thread.
anshumantech
Fri Sep 07, 2018 9:02 am
I am working on GPS module connected to Raspberry pi 3 via serial pins Tx, Rx with coding in Python 3.5.3 but i got following errors while i was trying to execute the code:
1. when i gave command as print (rcv.decode('ascii')) then i got error as “unicodedecodeerror:'ascii' codec can't decode the byte 0xff in position 0:ordinal not in range(128)” but when i gave command as print(rcv.decode('ascii','ignore')) then no error but it didn't print expected NMEA sentence data of GPS module.
2. if i removed the decode command then it gives the output in binary as given in doc file below.
I have attached pictures of errors and the code this code is working on Python 2.7 well but on python 3.5.3 it is not working. Please suggest any solution.
dgordon42
Fri Sep 07, 2018 1:17 pm
Python2 and Python3 handle ASCII and Unicode characters differently.
After the line:
rcv = port.read(400)
in your code, add the line:
rcv.encode('utf-8')
and see what happens.
Good Luck,
Dave.
anshumantech
Mon Sep 10, 2018 5:51 am
I have checked with the command rcv.decode('utf-8') after rcv = port.read() but it was giving error as "bytes object has no attribute as encode".
dgordon42
Mon Sep 10, 2018 10:26 am
anshumantech wrote:I have checked with the command rcv.decode('utf-8') after rcv = port.read() but it was giving error as "bytes object has no attribute as encode".
That is why I wanted you to try encode. Python2 will print bytes as ASCII characters, but Python3 will not. You need to encode the bytes into UTF-8 characters for Python3 to print them. That is what the "b'" characters in your output is trying to tell you, Python3's print function is not sure what to do with a byte, so it just prints "b". encode should change the bytes into UTF-8 characters so Python3 can print them.
Good Luck.
Dave.
