Stutter
Parrot OS
Thu Jun 09, 2016 10:31 pm
Just put parrot on my pi 3 mod b. Small issue. When I use the parrot root password it doesn't accept it. So my question is do I have to use raspberry root password to access root an Sudo commands on my OS that I loaded onto my pi
SonOfAMotherlessGoat
Re: Parrot OS
Thu Jun 09, 2016 10:46 pm
If it's another cheesy scriptkiddie leet hacker OS, have you tried the usual root/toor user/pass combo?
Account Inactive
Stutter
Re: Parrot OS
Fri Jun 10, 2016 2:09 am
Yes and it doesn't work.
B.Goode
Re: Parrot OS
Fri Jun 10, 2016 6:50 am
Can't help but smile at the irony of installing a distribution targeted at Penetration Testing and being unable to find the root password....
Your favourite internet search tool will probably return lots of hits suggesting that @soamg is correct.
It is unlikely that the credentials will be specific to the RPi build, so perhaps explore https://www.parrotsec.org and seek assistance there?
Re: Parrot OS
Fri Jun 10, 2016 8:02 am
Stutter wrote:Just put parrot on my pi 3 mod b. Small issue. When I use the parrot root password it doesn't accept it. So my question is do I have to use raspberry root password to access root an Sudo commands on my OS that I loaded onto my pi
Where did you download the .IMG file from ??????????????
Retired disgracefully.....
akahbc
Re: Parrot OS
Sun Jun 26, 2016 12:11 pm
log in as user parrot password parrot.
Then on the top of the screen is a root terminal. click that
Then use the passwd command to change the password.
:D
rithwik
Re: Parrot OS
Mon May 29, 2017 7:28 pm
┌─[[email protected]]─[~]
└──╼ $sudo passwd root
Enter new UNIX password: blahblah
Retype new UNIX password: blahblah
passwd: password updated successfully
Sam31337
Re: Parrot OS
Tue Mar 13, 2018 7:34 pm
rpi3 with Parrot-rpi-2017.11.15_armhf.img just worked with password of toor . so default username was parrot and I just typed in toor as password. it worked. then pull up terminal and type passwd and enter the password of your choice.
MidnightHacker537
Re: Parrot OS
Fri Aug 02, 2019 8:44 pm
The username is "parrot" and password is "toor". This should work! ;)
Andyroo
Re: Parrot OS
Fri Aug 02, 2019 9:26 pm
Welcome to the forum
Shame your post is a year late :roll: :mrgreen:
Please check the dates of posts and if the OP has ever been back (just click their name to see last date here).
Mods normally lock threads like this and class them as zombies.
Worry not, the record is over 6 years late :lol: :lol: :lol:
Return to “Other”
