NTAuthority
RPi3 Onboard WiFi not working on Windows 10 IOT
Wed Jun 08, 2016 11:41 am
Hey there, I'm new here so if you believe I posted this topic in the wrong section you're free to move it wherever you see fit. I've recently bought the Vilros Raspberry Pi 3 Ultimate Bundle which is packed with a Class 10 SanDisk 16GB MicroSD card. I installed Windows 10 IOT on it, following every single step. The problem is that the onboard wifi is not working, it's not even detected as such (See the attached image). Please help me, I can't understand what's wrong with it. I heard this might be due to a slow sd card but that's not in my case, a class 10 card should be more than enough. It's the last Windows IOT build (14342) so it does support onboard wifi. Please help me sort this out. :cry:
Re: RPi3 Onboard WiFi not working on Windows 10 IOT
Wed Jun 08, 2016 2:26 pm
NTAuthority wrote:Hey there, I'm new here so if you believe I posted this topic in the wrong section you're free to move it wherever you see fit. I've recently bought the Vilros Raspberry Pi 3 Ultimate Bundle which is packed with a Class 10 SanDisk 16GB MicroSD card. I installed Windows 10 IOT on it, following every single step. The problem is that the onboard wifi is not working, it's not even detected as such (See the attached image). Please help me, I can't understand what's wrong with it. I heard this might be due to a slow sd card but that's not in my case, a class 10 card should be more than enough. It's the last Windows IOT build (14342) so it does support onboard wifi. Please help me sort this out. :cry:
You will find similar posts in the W10 IoT Section of this Forum
viewforum.php?f=105
viewtopic.php?f=105&t=149120
NTAuthority
Wed Jun 08, 2016 4:41 pm
viewforum.php?f=105
Thanks! I've already looked up that topic.
