AntoineCompagnie
Unable to surf on the net with my RPi router
Tue Jun 07, 2016 4:25 pm
Hello everyone!
I just finished my router with my Raspberry Pi, I am even able to join its network which says that there is plenty of connection available. Yet when I connect to this network, nothing is able to load. Can you help me debugging this problem?
RaspberryPi 2 B - Inspiron 15 3000 series
topguy
Re: Unable to surf on the net with my RPi router
Wed Jun 08, 2016 1:46 pm
You probably have to fill in a lot of information before anyone can begin to help, we are not psychic you know.
AntoineCompagnie
Wed Jun 08, 2016 7:26 pm
Yes! But which one? I'm using an Inspiron 15 3000series, I used http://raspberrypihq.com/how-to-turn-a- ... fi-router/ and here are my wireless info:
:~ $ sudo cat /home/pi/wireless-info.txt
########## wireless info START ##########
Report from: 07 Jun 2016 21:44 CEST +0200
Booted last: 01 Jan 1970 01:00 CET +0100
Script from: 26 May 2016 21:56 UTC +0000
##### release ###########################
Distributor ID:    Raspbian
Description:    Raspbian GNU/Linux 8.0 (jessie)
Release:    8.0
Codename:    jessie
##### kernel ############################
Linux 4.4.9-v7+ #884 SMP Fri May 6 17:28:59 BST 2016 armv7l unknown unknown GNU/Linux
dma.dmachans=0x7f35, bcm2708_fb.fbwidth=656, bcm2708_fb.fbheight=416, bcm2709.boardrev=0xa01041, bcm2709.serial=0x23c7c566, smsc95xx.macaddr=<MAC 'eth0' [IF1]>, bcm2708_fb.fbswap=1, bcm2709.uart_clock=3000000, bcm2709.disk_led_gpio=47, bcm2709.disk_led_active_low=0, vc_mem.mem_base=0x3dc00000, vc_mem.mem_size=0x3f000000, dwc_otg.lpm_enable=0, console=ttyAMA0,115200, console=tty1, rootfstype=ext4, elevator=deadline, fsck.repair=yes, rootwait
##### desktop ###########################
sed: can't read /home/pi/.dmrc: No such file or directory
Could not be determined.
##### lspci #############################
./wireless-info: line 179: lspci: command not found
##### lsusb #############################
Bus 001 Device 006: ID 046d:c312 Logitech, Inc. DeLuxe 250 Keyboard
Bus 001 Device 005: ID 045e:0040 Microsoft Corp. Wheel Mouse Optical
Bus 001 Device 004: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
##### PCMCIA card info ##################
'pccardctl' is not installed (package "pcmciautils").
##### rfkill ############################
./wireless-info: line 192: rfkill: command not found
##### lsmod #############################
cfg80211              427855  0
rfkill                 16037  3 cfg80211,bluetooth
##### interfaces ########################
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet static
    address 192.168.10.1
    netmask 255.255.255.0
up iptables-restore < /etc/iptables.ipv4.nat
##### ifconfig ##########################
eth0      Link encap:Ethernet  HWaddr <MAC 'eth0' [IF1]>
          inet addr:192.168.0.33  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::c0f2:6df7:e27f:78c4/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:76586 errors:0 dropped:4 overruns:0 frame:0
          TX packets:41865 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:110458999 (105.3 MiB)  TX bytes:3619806 (3.4 MiB)
wlan0     Link encap:Ethernet  HWaddr <MAC 'wlan0' [IF2]>
          inet addr:192.168.10.1  Bcast:192.168.10.255  Mask:255.255.255.0
          inet6 addr: fe80::cc03:14b4:9a3a:c2b/64 Scope:Link
          RX packets:694 errors:0 dropped:3 overruns:0 frame:0
          TX packets:470 errors:0 dropped:30 overruns:0 carrier:0
          RX bytes:90884 (88.7 KiB)  TX bytes:78201 (76.3 KiB)
##### iwconfig ##########################
lo        no wireless extensions.
eth0      no wireless extensions.
wlan0     IEEE 802.11bgn  ESSID:"Dumbledore"  Nickname:"<WIFI@REALTEK>"
          Mode:Master  Frequency:2.412 GHz  Access Point: <MAC 'wlan0' [IF2]>
          Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality=2/100  Signal level=2/100  Noise level=0/100
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
##### route #############################
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.0.254   0.0.0.0         UG    202    0        0 eth0
169.254.0.0     0.0.0.0         255.255.0.0     U     303    0        0 wlan0
192.168.0.0     0.0.0.0         255.255.255.0   U     202    0        0 eth0
192.168.10.0    0.0.0.0         255.255.255.0   U     0      0        0 wlan0
##### resolv.conf #######################
nameserver 192.168.0.254
##### network managers ##################
Installed:
    None found.
Running:
    None found.
##### NetworkManager info ###############
NetworkManager is not installed (package "network-manager").
##### NetworkManager.state ##############
cat: /var/lib/NetworkManager/NetworkManager.state: No such file or directory
##### NetworkManager.conf ###############
grep: /etc/NetworkManager/NetworkManager.conf: No such file or directory
##### NetworkManager profiles ###########
No NetworkManager profiles found.
##### iw reg get ########################
Region: Europe/Brussels (based on set time zone)
country 00: DFS-UNSET
    (2402 - 2472 @ 40), (N/A, 20), (N/A)
    (2457 - 2482 @ 40), (N/A, 20), (N/A), NO-IR
    (2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, NO-IR
    (5170 - 5250 @ 80), (N/A, 20), (N/A), NO-IR
    (5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, NO-IR
    (5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, NO-IR
    (5735 - 5835 @ 80), (N/A, 20), (N/A), NO-IR
    (57240 - 63720 @ 2160), (N/A, 0), (N/A)
##### iwlist channels ###################
lo        no frequency information.
eth0      no frequency information.
wlan0     13 channels in total; available frequencies :
          Channel 01 : 2.412 GHz
          Channel 02 : 2.417 GHz
          Channel 03 : 2.422 GHz
          Channel 04 : 2.427 GHz
          Channel 05 : 2.432 GHz
          Channel 06 : 2.437 GHz
          Channel 07 : 2.442 GHz
          Channel 08 : 2.447 GHz
          Channel 09 : 2.452 GHz
          Channel 10 : 2.457 GHz
          Channel 11 : 2.462 GHz
          Channel 12 : 2.467 GHz
          Channel 13 : 2.472 GHz
          Current Frequency:2.412 GHz (Channel 1)
##### iwlist scan #######################
lo        Interface doesn't support scanning.
eth0      Interface doesn't support scanning.
Channel occupancy:
      1   APs on   Frequency:2.457 GHz (Channel 10)
      5   APs on   Frequency:2.462 GHz (Channel 11)
wlan0     Scan completed :
          Cell 01 - Address: <MAC 'Copain' [AC1]>
                    ESSID:"Copain"
                    Protocol:IEEE 802.11bg
                    Mode:Master
                    Encryption key:on
                    Bit Rates:54 Mb/s
                    Quality=48/100  Signal level=48/100
          Cell 02 - Address: <MAC 'FreeWifi' [AC2]>
                    ESSID:"FreeWifi"
                    Protocol:IEEE 802.11bgn
                    Mode:Master
                    Encryption key:off
                    Bit Rates:144 Mb/s
                    Quality=48/100  Signal level=69/100
          Cell 03 - Address: <MAC 'FreeWifi_secure' [AC3]>
                    ESSID:"FreeWifi_secure"
                    Mode:Master
                    Encryption key:on
                    Bit Rates:144 Mb/s
                    Extra:rsn_ie=30180100000fac020200000fac04000fac020100000fac010c00
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : TKIP
                        Pairwise Ciphers (2) : CCMP TKIP
                        Authentication Suites (1) : 802.1x
                    Quality=48/100  Signal level=61/100
          Cell 04 - Address: <MAC 'SoloNet-C3:88' [AC4]>
                    ESSID:"SoloNet-C3:88"
                    Mode:Ad-Hoc
                    Encryption key:off
                    Bit Rates:72 Mb/s
                    Quality=48/100  Signal level=46/100
          Cell 05 - Address: <MAC '' [AC5]>
                    ESSID:""
                    Mode:Master
                    Encryption key:on
                    Bit Rates:144 Mb/s
                    Extra:rsn_ie=30140100000fac040100000fac040100000fac020000
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                        Authentication Suites (1) : PSK
                    Quality=20/100  Signal level=10/100
          Cell 06 - Address: <MAC 'patate' [AC6]>
                    ESSID:"patate"
                    Mode:Master
                    Encryption key:on
                    Bit Rates:144 Mb/s
                    Extra:wpa_ie=dd160050f20101000050f20401000050f20401000050f202
                    IE: WPA Version 1
                        Group Cipher : CCMP
                        Group Cipher : CCMP
                    Quality=97/100  Signal level=10/100
##### module infos ######################
libkmod: ERROR ../libkmod/libkmod.c:557 kmod_search_moddep: could not open moddep file '/lib/modules/4.4.9-v7+/modules.dep.bin'
modinfo: ERROR: Module alias cfg80211 not found.
[cfg80211]
##### module parameters #################
[cfg80211]
cfg80211_disable_40mhz_24ghz: N
ieee80211_regdom: 00
##### /etc/modules ######################
i2c-dev
##### modprobe options ##################
[/etc/modprobe.d/ipv6.conf]
alias net-pf-10 off
[/etc/modprobe.d/libpisock9.conf]
blacklist visor
##### rc.local ##########################
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
sudo ifplugd eth0 --kill
sudo ifup lan0
exit 0
##### pm-utils ##########################
[/etc/pm/sleep.d/74ifplugd] (755 root)
[ -f /etc/default/ifplugd ] || exit 0
. /etc/default/ifplugd
[ "$SUSPEND_ACTION" ] || [ "$SUSPEND_ACTION" != "none" ] || exit 0
if [ "$SUSPEND_ACTION" = "suspend" ] ; then
  RESUME_ACTION="resume"
elif [ "$SUSPEND_ACTION" = "stop" ] ; then
  RESUME_ACTION="start"
else
  exit 0
fi
[ -f "${PM_FUNCTIONS}" ] && . "${PM_FUNCTIONS}"
IFPLUGD_STATE="ifplugd_ifs"
elem_of() {
    local E=$1
    shift
    echo $@ | grep -Eq "(\\<all\\>)|(\\<${E}\\>)"
save_state() {
    savestate ${IFPLUGD_STATE} 2>/dev/null
load_state() {
    restorestate ${IFPLUGD_STATE} 2>/dev/null
filter_hotplug_ifs() {
    while read L; do
        for IF in $L; do
            # interface is managed statically
            elem_of "${IF}" "${INTERFACES}" && continue
            # interface is not managed by udev
            elem_of "${IF}" "${HOTPLUG_INTERFACES}" || continue
            # ignore lo
            [ "x${IF}" = "xlo" ] && continue
            echo -n "${IF} "
        done
    done
    echo ""
get_running_ifs() {
    ps --no-headers -o args -C ifplugd | \
    sed -e 's/.*-[[:alpha:]]*i[[:space:]]*\([^[:space:]]\+\).*/\1/' | \
    filter_hotplug_ifs
get_hotplug_ifs() {
    local IFACES=""
    for IF in /sys/class/net/*; do
        echo "${IF##*/} "
    done | filter_hotplug_ifs
stop_udev_ifs() {
    local ACTION=$1
    local IFACES
    local IF
    IFACES=`get_running_ifs`
    # save list of interfaces we stop, so we can restart them
    echo "${IFACES}" | save_state || true
    for IF in ${IFACES}; do
        if [ "x${ACTION}" = "xsuspend" ]; then
            ifplugd -i ${IF} -S
        else
            ifplugd -i ${IF} -k
        fi
        # ifplugd started by udev doesn't take down the IF
        /etc/ifplugd/ifplugd.action ${IF} down
    done
start_udev_ifs() {
    local ACTION=$1
    local IFACES
    local IF
    # try to load list of interfaces
    # if it can't be loaded, we just start all hotplug interfaces
    IFACES=`load_state || get_hotplug_ifs`
        if [ "x${ACTION}" = "xresume" ] && ifplugd -i ${IF} -c; then
            ifplugd -i ${IF} -R
        else
            # start ifplugd just as udev would
            INTERFACE=${IF} ACTION=add /lib/udev/ifplugd.agent
        fi
    done
case "$1" in
        hibernate|suspend|suspend_hybrid)
                /etc/init.d/ifplugd ${SUSPEND_ACTION}
                stop_udev_ifs ${SUSPEND_ACTION}
        thaw|resume)
                if [ "x$2" != "xstandby" ]; then
                    start_udev_ifs ${RESUME_ACTION}
                    /etc/init.d/ifplugd ${RESUME_ACTION}
                fi
        *) exit 1
esac
exit 0
##### udev rules ########################
##### dmesg #############################
[    8.586659] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    9.926089] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[    9.926633] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.205215] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   11.714357] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   11.716151] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
########## wireless info END ############
topguy
Wed Jun 08, 2016 10:00 pm
Are you trying to create a separate network or are you trying to extend your existing network. I see that the guide your following do the first thing, I just want to make sure that is what you are trying to do.
I also see that the guide is from 2014 which means that its made for Raspian Wheezy. If you are using an up to date version of Raspbian then you have Raspian Jessie.
There are significant changes to network setup. Among other things it is now recommended to use dhcpc.conf for network setup instead of /etc/network/interfaces.
There are multiple posts on this subject on the forum ( and elsewhere: http://raspberrypi.stackexchange.com/qu ... -static-ip )
I cant say that this is the exact reason for your problem.
You say that you can connect to the ssid that the Pi controls, can we get some details on that connection. ( ip-address, netmask, gateway, DNS )
drgeoff
Wed Jun 08, 2016 11:13 pm
dhcpcd.conf
AntoineCompagnie
Thu Jun 09, 2016 12:04 am
Thank you for considering my question!
are you trying to create a separate network or are you trying to extend your existing network.
I want to transform my Raspberry Pi as an highly secured router to navigate anonymously wherever I would be thanks to Onion Pi. Therefore, I am not sure about creating a separate network or extending my existing one but I feel I am trying to create a separate network...
I understand what you said and am on my way to jump on the link.
Here is from File: /etc/network/interfaces
# Include files from /etc/network/interfaces.d:
auto lo
allow-hotplug wlan0
And here is from File: /etc/dhcp/dhcpd.conf :
#added
subnet 192.168.10.0 netmask 255.255.255.0 {
        range 192.168.10.10 192.168.10.20;
        option broadcast-address 192.168.10.255;
        option routers 192.168.10.1;
        default-lease-time 600;
        max-lease-time 7200;
        option domain-name "local";
        option domain-name-servers 8.8.8.8, 8.8.4.4;
File: /etc/hostapd/hostapd.conf
# Basic configuration
interface=wlan0
ssid=Dumbledore
channel=1
#bridge=br0
# WPA and WPA2 configuration
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=3
wpa_passphrase=**********
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
# Hardware configuration
driver=rtl871xdrv
ieee80211n=1
hw_mode=g
device_name=RTL8192CU
manufacturer=Realtek
AntoineCompagnie
Thu Jun 09, 2016 3:05 pm
I carefully followed step by step http://raspberrypi.stackexchange.com/qu ... -static-ip. Yet, when connecting to the RPi router, I'm still not able to connect to Internet...
