harikmarthin
error updateing. please help me!!!
Thu Jun 02, 2016 9:40 am
i get this error code.
sudo apt-get update
Hit http://ftp.debian.org experimental Release.gpg
Hit http://mirrordirector.raspbian.org wheezy Release.gpg
Hit http://raspberrypi.collabora.com wheezy Release.gpg
Hit http://ftp.debian.org experimental/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://ftp.debian.org experimental/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Hit http://ftp.debian.org experimental/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://ftp.debian.org experimental/contrib Translation-en
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Hit http://ftp.debian.org experimental/main Translation-en
Hit http://ftp.debian.org experimental/non-free Translation-en
Hit http://archive.raspberrypi.org wheezy Release.gpg
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en_GB
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Reading package lists... Done
W: Ignoring Provides line with DepCompareOp for package php-psr-cache-implementation
W: You may want to run apt-get update to correct these problems
can you help me ? ;(
paulie
Re: error updateing. please help me!!!
Thu Jun 02, 2016 9:41 pm
There's no problem there.
apt is a command line package handling tool, which gets its data sources as listed in /etc/apt/sources.List
Those 'hit' messages shows that the sources have been found online: you should see some more messages, then be returned to the command prompt.
From there, you can run apt-get upgrade or apt-get install [packagename] to install a specific package.
You should be able to get more information from the man apt-get command.
It has been my custom to use Xeyes
paulie
Thu Jun 02, 2016 9:51 pm
You should be able to get more information from the man apt command.
Edit: have just seen the two w (warnings) at the end of your post - never got them myself. You could try apt-get update again, and see if it solves it.
joan
Thu Jun 02, 2016 10:13 pm
Unless I have missed an announcement you should NOT be using a Debian archive. The Raspbian archives were created for the old ARM architecture used by most Pi models.
paulie
Thu Jun 02, 2016 10:35 pm
joan wrote:Unless I have missed an announcement you should NOT be using a Debian archive. The Raspbian archives were created for the old ARM architecture used by most Pi models.
Oops! I didn't notice that... :oops:
