It looks as if all is good on the Pi's side:
But doing a "ping -a xxx.xxx.xxx.xxx" returns "DEBIAN" as the hostname:
Any ideas?
Thanks! You were correct, it is a network issue. The problem does not exist when directly connected to the Pi.cpc464 wrote:The pi has been renamed correctly but your Windows machine still thinks it is called "DEBIAN". The Pis IP address is still being resolved to "DEBIAN" either by your Windows machine's local host file or (more likely) a naming service on your network, such as DHCP on your router. You could try waiting 24 hours, or maybe reboot the router, if there is one, or the Windows box.
not network problemblauvster wrote:Thanks! You were correct, it is a network issue. The problem does not exist when directly connected to the Pi.cpc464 wrote:The pi has been renamed correctly but your Windows machine still thinks it is called "DEBIAN". The Pis IP address is still being resolved to "DEBIAN" either by your Windows machine's local host file or (more likely) a naming service on your network, such as DHCP on your router. You could try waiting 24 hours, or maybe reboot the router, if there is one, or the Windows box.
