sshukes wrote:Currently I have 2 pi's and a 2 5vFans wired up. I am using as a benchmark.
If I use the distributed power supply my speed is 400pmk/s using the single wall plug in it is 750 pmk/s. Everything else is the same.
aircrack-ng seems to be a wireless thing and it is possible that different power supplies could have differing effects on the hardware and/or transmissions. If there is more or less ripple or EMI from one supply or the other that could create a difference.
A single supply would give a common 0V in the supply for both Pi's and circuits, where two isolated wallwart supplies may leave both with their own 'floating' 0V. That could have different effects including how things present themselves as ground planes.
I would suggest comparing how a Pi using both walwart and distributed supply benchmarks with the other Pi only on its own wallwart supply, then reversed. Perhaps benchmark with three Pi's, one always on wallwart, doing that three times with different Pi's on the wallwart to see if the difference is reproducible and consistent.
