Best Raspberry PI users,
I am having some strange issues with my raspberry pi combined with the wifi adapter.
I have a Raspberry PI model B (one of the first versions)
and I have a TP-link TL-WN-823N wifi adapter.
The PI is running the latest version of raspbian Jessie.
I have setup the adapter to connect to the wifi automatically using the wpa-supplicant information.
The network connects normally without any issues.
The issue is that at some times, when I try to connect to the pi it takes an amazing long time before it connects, if it doesn't time out.
Also when I ping the PI it takes some requests before it responds, also when it responds the respond times are very inconsistent, sometimes more than 100ms and sometimes 5ms.
I have checked/ tried to following things:
I have added mac_usb_current=1 only to find out that was for B+ and newer :S
I have checked to power managerment this is currently off.
I have checked other wireless devices, these have latency of 1 - 3ms per ping.
Also I have checked the wired connection, and this ping is also 1 - 3ms per ping.
Do you have any idea's of things I can try? Or perhaps a fix for this issue?
Kind Regards and Thanks in Advance,
Jasper van Rijbroek
