langera
No network. ip route has no default
Sat May 28, 2016 8:30 am
A new raspberry pi 2 out of the box has no network.
Both wireless and a cable fail to connect to the network although when connecting the cable, the icon seem to suggest its connected.
Tried to follow some of the troubleshooting guides:
"ip addr"
seems to return the required eth0 state UP.
"ifconfig -a"
Also looks ok as far as I can see
eth0      Link encap:Ethernet  HWaddr b8:27:eb:3c:ca:40
          inet addr:10.0.0.12  Bcast:10.0.0.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:109 errors:0 dropped:0 overruns:0 frame:0
          TX packets:31 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:19381 (18.9 KiB)  TX bytes:4626 (4.5 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:1072 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1072 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:92700 (90.5 KiB)  TX bytes:92700 (90.5 KiB)
wlan0     Link encap:Ethernet  HWaddr 00:0f:60:07:1d:19
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
"ip route" returns:
10.0.0.0/24 dev eth0 proto kernel scope link src 10.0.0.12 metric 202
And does not have the expected default 192.168.*.* etc.
Anyone knows what could be wrong?
epoch1970
Re: No network. ip route has no default
Sat May 28, 2016 1:46 pm
You should post the contents of your /etc/network/interfaces file.
The answer lies there I guess.
(I'd say the Pi has network, but it doesn't have the Internet. The default route is missing.)
langera
Sat May 28, 2016 2:39 pm
Thanks for your reply.
/etc/network/interfaces file is:
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet manual
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
auto wlan1
allow-hotplug wlan1
iface wlan1 inet manual
and wpa_supplicant.conf also looks OK (I changed the real ssid + password)
update_config=1
network={
	ssid="********"
	key_mgmt=NONE
	wep_key0="**********"
epoch1970 wrote:You should post the contents of your /etc/network/interfaces file.
epoch1970
Sat May 28, 2016 3:20 pm
Gah. Thanks, you did all right but I was wrong.
Your setup lies within dhcpcd config files, and unfortunately I don't use that so I can't help you further.
Look around, though, on the forum and man pages, the issue is probably already documented.
In the meantime, assuming your network is 10.0.0.0/24 and your router sits at 10.0.0.1 (that's what I surmise from the ifconfig you posted), you could check if "ip route add default via 10.0.0.1" adds the default route I think this is all about, and gives your Pi access to the internet.
You can remove it afterwards with "ip route del default".
(Also, I think it's better to activate one interface at a time. Leave wlan0 down the way it is, and just use eth0 for a start. Or the other way around, if you prefer. I don't know what dhcpcd has in store for this but out-of-the-box, linux gets confused if there are multiple default gateways.)
DirkS
Sat May 28, 2016 3:31 pm
update_config=1
network={
	ssid="********"
	key_mgmt=NONE
IIRC you don't use quotes around the wep key entry
