sachinwable wrote:Hi,
I am a software guy with limited knowledge of electronics doing some experiments on pi.
I have pi3 model B and a 1 channel relay of 5 V. Can I use these 2 to complete a circuit that powers on my TV or Fan or Bulb? I am afraid of burning my pi if i use it with a relay completing a circuit with mains
Thank you,
Sachin
if you connect it correctly, you can complete the mains circuit.
if you connect it wrongly, you can burn your pi3, and also yourself
if you are looking for the solution, take something pre-built
if you are looking for experiments, try it with lower voltage/current and at the end connect to mains.
You could build a box with proper connectors to avoid flying mains cables
PS: you should also check the relay specs to know if it can work safely with the raspi..
