Sventovit
Need help for an issue with NUT
Fri May 27, 2016 7:03 am
Hi all.
I have installed NUT on my Raspberry Pi to monitor my Eaton UPS.
If there’s a power failure the UPS shutdown the RPI.
That’s OK.
But when the power comes back, the RPI restart
and then, reboots.
The timer in NOTIFYCMD
let "n = 600"
makes it reboot after 10 mn’s wait (if value is changed to 900, the RPI reboot after 15mn).
And I don’t get why.
This is the whole enchilada:
/etc/default/nut
# start upsd
START_UPSD=yes
# start upsmon
START_UPSMON=yes
/etc/nut/ups.conf
[eaton]
driver = usbhid-ups
port = auto
desc = "Eaton3S"
/etc/nut/nut.conf
standalone
/etc/nut/upsd.conf
# LISTEN <address> <port>
LISTEN 127.0.0.1 3493
LISTEN ::1 3493
/etc/nut/upsd.users
[admin]
password = mypass
actions = SET
instcmds = ALL
[upsmon]
password = mypass
upsmon master
/etc/nut/upsmon.conf
MONITOR eaton@localhost 1 admin mypass master
MINSUPPLIES 1
FINALDELAY 5
SHUTDOWNCMD "sudo /sbin/shutdown -h +0"
NOTIFYCMD "/etc/nut/notifycmd"
NOTIFYFLAG ONBATT EXEC+SYSLOG+WALL
NOTIFYFLAG ONLINE EXEC+SYSLOG+WALL
NOTIFYCMD /etc/nut/notifycmd
And finally, NOTIFYCMD:
/etc/nut/notifycmd
#!/bin/bash
# NUT NOTIFYCMD script
PATH=/sbin:/usr/sbin:/bin:/usr/bin:/usr/local/sbin:/usr/local/bin
trap "exit 0" SIGTERM
if [ "$NOTIFYTYPE" = "ONLINE" ]
then
        echo $0: power restored | wall
        curl "command"
        #sleep 5
        # Cause all instances of this script to exit.
        killall -s SIGTERM `basename $0`
fi
if [ "$NOTIFYTYPE" = "ONBATT" ]
then
        echo $0: 10 minutes till system powers down... | wall
        curl "command!"
        # Loop with one second interval to allow SIGTERM reception.
		let "n = 600"
        while [ $n -ne 0 ]
        do
                sleep 1
                let "n--"
        done
        echo $0: commencing shutdown | wall
        upsmon -c fsd
fi
That’s it.
I wish you can help me to find the reason of this issue..
