mkyb14
Pi Zero v1.3 - USB Not Working
Fri May 27, 2016 1:13 am
Has anyone had issues with USB not working on the newer pi zero?
OTG cable (that works), has no luck on this device with logitech unify receiver, or a traditional wired keyboard. test both on another machine and they work.
Even bought a hubpixd usb hub and that's not working either.
USB and pwr usb both work and power on the device. Just at a loss as to why I can't get this to recognize any input device.
broe23
Re: Pi Zero v1.3 - USB Not Working
Fri May 27, 2016 6:53 am
Which port are you plugging into? See this for the port info. https://cdn-reichelt.de/bilder/web/xxl_ ... IBUNG2.png
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good.
mkyb14
Fri May 27, 2016 3:24 pm
the one labeled USB. I read the instructions and made sure.
Cancelor
Fri May 27, 2016 5:39 pm
Is an OTG cable the right one? What are you connecting to?
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
Dis93
Fri May 27, 2016 5:41 pm
I got a OTG cable in a bundle from PiHut. It didn't work on the Zero. It worked on a phone. Someone on Reddit had the same bundle and same issue. I got a replacement from PiHut and the replacement worked fine.
