loopylee
temperature logging.
Thu May 26, 2016 8:13 pm
I am a new user and dont have too much idea what im doing.
I have a respberry pi 3 which i have set up running raspbian.
I have also installed a temperv14 usb thermometer which i have working fine.
To get a reading im having to open the treminal and type "sudo temper14"
This gives me a lime of txt with the date, time and temperature.
Is there a way to get this to run every 30 minutes and record the results in a txt file?
Thank you for your time.
Lee
Gavinmc42
Re: temperature logging.
Fri May 27, 2016 2:41 am
Make a shell script file
read the data then echo $data >> /home/pi/data.file
You can date, time stamp it and format as a csv file, like this.
filedate="$( date +"%Y_%m_%d")"
datenow=$(date)
echo $datenow, $temp1, $temp2, $temp3...>> /home/pi/logs/$filedate.csv
Then just call the shell script from cron
I'm dancing on Rainbows.
sachinwable
Fri May 27, 2016 11:51 am
You can set a cron job to run that every 30 minutes.
PiGraham
Fri May 27, 2016 11:56 am
See this similar query
viewtopic.php?f=28&t=149573
