I have Rpi2 running raspbian, I use it for many purposes, recently it started changing volume letters. Normal mount setup would look like this:
Device Boot Start End Blocks Id System
/dev/sda1 1 409639 204819+ ee GPT
/dev/sda2 409640 623872871 311731616 b W95 FAT32
WARNING: GPT (GUID Partition Table) detected on '/dev/sdc'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdc: 500.1 GB, 500107859968 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773164 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
/dev/sdb1 1 409639 204819+ ee GPT
/dev/sdb2 411648 976773119 488180736 7 HPFS/NTFS/exFAT
fstab looks like this:
proc /proc proc defaults 0 0
/dev/mmcblk0p1 /boot vfat defaults 0 2
/dev/mmcblk0p2 / ext4 defaults,noatime 0 1
/dev/sda2 /media/Share exfat defaults,umask=000 0 0
/dev/sdb2 /media/Share2 exfat defaults,umask=000 0 0
