montezuma
How to use 1024x600 resolution ?
Sat Aug 18, 2012 4:11 pm
I have bought a small portable TV (Medion 83688) with a screen resolution 1024x600 and an HMDI input:
http://aldi.medion.com/md83688_01/nord/ ... tung_anker
Unfortunately the Raspberry PI (with debian) uses 1024x768 when connected to this TV, so the picture is scaled down :|
Can anybody help me to set-up my Raspberry PI to use 1024x600 resolution?
dom
Re: How to use 1024x600 resolution ?
Sat Aug 18, 2012 4:25 pm
Unfortunately this is not possible currently.
1024x600 is not a standard DMT or CEA HDMI resolution, and so isn't supported. Only the standard modes are supported, shown here:
http://elinux.org/RPi_config.txt
There is a plan to allow arbitrary resolutions/framerates to be supported, but it probably won't be for a while.
lucaspirolla
Wed Mar 20, 2013 3:17 pm
any news about the 1024x600 resolution on RPi??
dom
Wed Mar 20, 2013 5:29 pm
typ.o
Thu May 29, 2014 5:53 am
managed to set up my 1024 x 600 display using these settings
edit your config.txt file typing
sudo nano /boot/config.txt
here i filled in the settings from adafruit:
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1024
#framebuffer_height=600
#hdmi_ignore_edid=0xa5000080
hdmi_cvt=1024 600 60 3 0 0 0
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=87
everything works fine!
CodemanAtHopedesks
Sat Nov 07, 2015 5:05 am
all i needed to make my 7inch 1024 x 600 work was (based on the previous replies, thanx):
and add
disable_overscan=1
hdmi_cvt=1024 600 3 0 0 0
save (CTRL + O)
sudo reboot
turtlegood
Fri Dec 04, 2015 10:35 am
Thanks this is a useful post solving my problem!
However I think your solution is a little wrong.
I think it must be:
disable_overscan=1
You forgot a '60', which is the frquency of refreshing (Hz).
For detailed things, see: viewtopic.php?f=29&t=24679
A Chinese High School Student
hardmouse
Wed Apr 17, 2019 6:54 pm
To whom might have same mistake that I made and fin out your screen is actualIy 800x480 not 1024x800, I found another similar solution here, and it solve my issue:
https://learn.adafruit.com/adafruit-5-8 ... pi-config
Basically just update/add the code in following:
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=87
hdmi_cvt=800 480 60 6 0 0 0
hdmi_drive=1
