kelvinlow
Facing 'No such file' on LXTerminal but work fine via SSH
Mon May 23, 2016 7:52 am
Hello, I am building an OpenCV application.
I'm following the instruction of the link below.
https://github.com/garystafford/object- ... g-blogpost
I had built the project, according to the instruction
I used
./cppappopencv
to execute the application after cd to the right location.
The application works when I using SSH to connect to my Raspberry Pi
Also, I built/compilied application via SSH, and it's works.
(I'm using OS X, iTerm 2)
But when I do so on the LXTerminal in Raspberry Pi,
./cppappopencv
I am facing error:
error while loading shared libraries: libcvblob.so: cannot open shared object file: No such file or directory
I tried to locate libcvblob.so and I found it's available.
and I also tried new SSH to connect to Raspberry Pi, and it works too.
topguy
Re: Facing 'No such file' on LXTerminal but work fine via SS
Mon May 23, 2016 11:14 am
But WHERE is it available ?
This little snippet from the guide you linked to is relevant.
# optional - fixed problem with app finding cvBlob library when started
echo 'export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH' | sudo tee -a ~/.bashrc
bash --login # or exit VM and log back in
Do "echo $LD_LIBRARY_PATH" in each shell and see if there is a difference.
