It won't case any damage to the actual Pi itself either correct? Looking into upgrading my SD card to either a Samsung Evo + or a Samsung Evo Pro.gregeric wrote:If the card in question is UHS then it's designed to be clocked at 100MHz, albeit when supplied with 1V8. Anyway, how are the card manufacturer going to know how fast it's been clocked? I wouldn't worry too much about the warranty, more so my data.
On a Pi you are (ab)using the UHS card with SDIO v2, 3V3 i/o, high speed 50Mhz mode overclocked to 100MHz. I have no idea if the lifespan of the card will be impacted: I'm guessing the reduced supply at higher frequencies is more to do with slew rates, and seeing as it seems to work OK at 3V3 I'm happy to continue to use it myself.
It won't damage the Pi or affect the Pi's warranty.MartinPi wrote:It won't case any damage to the actual Pi itself either correct? Looking into upgrading my SD card to either a Samsung Evo + or a Samsung Evo Pro.
It won't damage the Pi or affect the Pi's warranty.[/quote]dom wrote:[quote="MartinPi"It won't case any damage to the actual Pi itself either correct? Looking into upgrading my SD card to either a Samsung Evo + or a Samsung Evo Pro.
The price of them both is £23 for the Pro; and £16 for the Evo. So you'd say that's not worth the increase in price?Dis93 wrote:Another vote for the EVO+ here. (2 cards overclocked)
Pro seems overpriced.
Actually been reading this; what benchmark should I be focused most on? He does a random write but what about random read speeds?Dis93 wrote:AHA!
http://www.pidramble.com/wiki/benchmarks/microsd-cards
fruitoftheloom linked it in your other thread on this topic.
When studying the random read writes of both the Pro and the Evo+ on Amazon (screenshots for the disk speed test); the Pro still comes out first.Dis93 wrote:AHA!
Thanks for all the help; just going to read more into it and see what kind of speed increase it is against my Ultra 32GB.Dis93 wrote:On one hand I have to agree with you that the Pro is faster, and as I said more expensive. That may or may not be an issue.
On the other hand I agree with broe23's assertion that shifting the OS to an SSD will give better results, again cost may or may not be an issue.
On my third hand/tentacle, the RPi ain't really a speed demon compared to other SBCs, and as such it's strengths lay in support and userbase, and maybe it isn't really a valid desktop replacement.
One last question, I'm using my Pi with a 5V 2.5A power supply, the official one from the Pi hut, would that be suitable for overclocking the SD bus to 100mhz?dom wrote:It won't damage the Pi or affect the Pi's warranty.MartinPi wrote:It won't case any damage to the actual Pi itself either correct? Looking into upgrading my SD card to either a Samsung Evo + or a Samsung Evo Pro.
The official supply is very good, so will be fine for this.MartinPi wrote: One last question, I'm using my Pi with a 5V 2.5A power supply, the official one from the Pi hut, would that be suitable for overclocking the SD bus to 100mhz?
While money isn't that much of an issue between the two; can't justify getting both with my use case requiring only one card and I already have enough backup cards :/Dis93 wrote:Buy one of each and report your results?
Did you notice a great perfromance increase with your upgrade to the Evo?Dis93 wrote:I started with PNY Transcend 16GB, which I overclocked. No problems.
I got a Kingston, which crapped out and I had to ditch.
Following advice from this forum I got EVO+ 32Gb cards, worked fine, work fine-erer overclocked.
