slo
Run command at startup as different user
Sat May 21, 2016 11:24 pm
I am running Jessie Lite Raspbian with no GUI.
I have installed Google "Cups Connector" to use with google cloud print. It works good but...
The trouble I am having is having the program start on boot.
The install instructions had me create a user gcp and group gcp, and gcp owns all the program files.
The way I have to get it to run is with the following command:
sudo -H -u gcp /opt/gcp_cups_connector/gcp-cups-connector -config-filename /etc/gcp_cups_connector/gcp-cups-connector.config.json
How can I have this run on startup? Note the second part of the command needs to point to a config file.
I found some dated instructions that do not work, but recommend editing /etc/rc.local file to include the following:
su --login --command /opt/gcp_cups_connector/gcp-cups-connector -config-filename /etc/gcp_cups_connector/gcp-cups-connector.config.json pi &
As I said, that doesn't work. It has wrong user, wrong file location, and does not point to the config file.
So, how do I get the correct command to run at boot?
MarkHaysHarris777
Re: Run command at startup as different user
Sun May 22, 2016 3:38 am
A print server should be run at startup from systemd (systemctl) as a service.
Systemd has a learning curve. Start with the basics (and a google search) on how to setup a server, what config files to create, and how to enable it.
post here is you have questions as you proceed
marcus
:ugeek:
epoch1970
Sun May 22, 2016 10:36 am
On Google's Github pages
https://github.com/google/cups-connecto ... ly-on-Boot
You'll find different ways of running the daemon.
slo
Sun May 22, 2016 10:51 am
Thanks Google's wiki very confusing. Didn't realize Raspbian uses systemd.
Use first option not third on this page: https://github.com/google/cups-connecto ... ly-on-Boot
broe23
Sun May 22, 2016 4:47 pm
Using a Headless server is not the issue. It is setting up Google Print Server with all of the apt's that it needs. Also you need CUPS installed and a printer that uses ARM drivers, which there are very few out there.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good.
MarkHaysHarris777
Mon May 23, 2016 6:32 pm
slo wrote:Thanks Google's wiki very confusing. Didn't realize Raspbian uses systemd.
Yes, as an aside, Raspbian is based on Debian. Debian 8 moved to Systemd by default; consequently Raspbian Jessie also moved to Systemd by default. Raspbian Wheezy previously used Sysvinit.
marcus
:ugeek:
