epoch1970
Pi3, serial console over bluetooth?
Fri May 20, 2016 12:37 pm
Currently my Pi3 runs sshd but I'd like to add serial console access via Bluetooth.
I have read some posts about this but I find the information confusing. I am only interested in Pi 3. I don't know the difference between a mini-UART and a PLxxx (and I think I don't care), etc.
Could someone give me a simple recipe as how to setup the bootconfig (and possibly the bluetooth software) and obtain something like /dev/ttyS0 on the Pi?
Thanks in advance.
Douglas6
Re: Pi3, serial console over bluetooth?
Fri May 20, 2016 3:12 pm
See if this helps to setup a Bluetooth console: viewtopic.php?p=955425#p955425
epoch1970
Fri May 20, 2016 3:27 pm
Thanks!
That was one of the threads I started with. Then in got lost in bootcmd.txt and core frequency stuff :)
Douglas6
Fri May 20, 2016 3:41 pm
I ignore (read: don't understand) all that business of swapping UARTs. The linked recipe works on a clean Raspbian install.
epoch1970
Fri May 20, 2016 7:31 pm
And I confirm it runs fine (from an OS X machine), thanks again.
With your systemd units, all starts automagically at boot, this is great.
To be clear for others who might come around here, this serial-over-bluetooth link does not give access to the boot messages (I suppose it starts too late anyway), it offers a terminal from which you can login. Since it works in case networking has completely failed, that's just fine for me.
I have derived a little bit from the reference thread, in that my rfcomm service runs as:
"ExecStart=/usr/bin/rfcomm watch hci0 1 /sbin/getty rfcomm0 115200 vt100", I've removed "-a pi" which would have auto-logged in as user pi. So instead I arrive at a login: prompt and I have to input login and password to get access.
After login I get an annoying message coming from my login shell:
-bash: cannot set terminal process group (1245): Inappropriate ioctl for device
-bash: no job control in this shell
(1245 is the /usr/bin/rfcomm process)
After a few man pages and googling a bit I didn't figure out how to fix it. But the session works, by and large.
NB: If you need sudo, you'll need to invoke "sudo -S <command>".
I started fantasizing I could ditch the old and ugly linux netbook I carry around as my admin station and connect to the Pi via an iPhone or an iPad.
I couldn't find an app that would discover the BT serial link and use it. If anyone has a suggestion, I'd like to try that out.
EDIT: D'oh. My netbook doesn't have BT built-in :D I guess I'll look into an android tablet then. Some seem adequately affordable.
Douglas6
Fri May 20, 2016 8:03 pm
Glad to hear it's working for you. I haven't determined what that warning means either.
As far I know iOS doesn't support a Serial Port Profile, so I think you're out of luck there.
owendelong
Mon Aug 20, 2018 4:39 am
Care to share how you did this so I don't have to repeat your searches?
I use screen (available on virtually every real operating system). I suspect there's plenty of solutions for Windows, too.
screen /dev/cu.<whatever it got called>
Was all I needed on Macs and Linux systems I tried.
weo1rpi
Thu Dec 06, 2018 2:31 am
I use the utility "screen". I run it in my bluetooth console window with
no parameters and then job control seems to work fine.
With this addition bluetooth console is very usable.
Bill
owendelong
Thu Feb 21, 2019 4:35 am
I finally found an answer to the job control problem...
Here's the solution... Add "setsid" to your /etc/systemd/system/rfcomm.service file as follows:
[Unit]
Description=RFCOMM service
After=bluetooth.service
Requires=bluetooth.service
[Service]
ExecStart=/usr/bin/rfcomm watch hci0 3 setsid /sbin/agetty -L rfcomm0 115200
[Install]
WantedBy=multi-user.target
You can see it there just before /sbin/agetty in the [Service] section. This causes agetty to be launched in a new "session" (aka Linux Process Group) which enables job control and all the other fun things you expect a controlling terminal to be able to do.
Return to “Beginners”
