owaizshareef
Static ip - no internet
Thu May 19, 2016 11:05 pm
i have used "sudo nano /etc/dhcpcd.conf" and added static address, after reboot the raspberry pi shows static address in ifconfig and i can also access it using putty, but it is not able to connect to the internet. i have checked the router and this device does not show up. I am sure there is nothing wrong with the router or cable as i was able to access internet before setting the static ip address.
lines i have typed.. "interfaces eth0
static ip_address=192.168.1.150
static routers=192.168.1.1
static domain_name_servers=192.168.1.1"
topguy
Re: Static ip - no internet
Fri May 20, 2016 10:57 am
Is the 150 address inside or outside of the router DHCP pool of adresses ?
Some routers only show devices that have an active lease but others show all devices (MAC-addresses) it can see.
I dont know if some routers will refuse traffic from addresses within the DHCP-pool but without an active lease.
How did you test for internet connection ? Have you tried to ping 8.8.8.8 for example ?
I just want to differentiate between a routing problem and DNS problems.
Sat May 21, 2016 7:28 am
Run the following commands and post the results here
ifconfig -a
ip route
ping -c3 $(ip route | awk '/default/ {print $3}')
ping -c3 8.8.8.8
ping -c3 google.com
cat /etc/resolv.conf
mehdi.heris
Mon Mar 20, 2017 11:32 pm
did you resolve your issue? I have the same problem. Would you post the results?
SurferTim
Tue Mar 21, 2017 12:36 am
You should follow DougieLawson's post and do what he suggests.
If you had no problems with dhcp network settings, revert to that setting and post the same.
murksiuke
Sat Nov 10, 2018 1:21 pm
I know this is an old post, but i have the same problem.
Ping results in 'destination host unreachable'
Ip route is 'default via 192.168.0.1 dev wlan0 src 193.168.0.10 metric 303 192.168.0.0/24 dev wlan0 proto kernel scope link src 192.168.0.10 metric 303'
Sat Nov 10, 2018 1:23 pm
murksiuke
Sat Nov 10, 2018 1:28 pm
Please see my reply viewtopic.php?f=91&t=226637&p=1390306#p1390306
So the static ip adress i chose is ivalid? Thank you,i will try to fix it
DirkS
Sat Nov 10, 2018 1:35 pm
Looks like you tried to set 193.x.x.x instead of 192.x.x.x
murksiuke
Sat Nov 10, 2018 11:28 pm
Well thats embarrassing. :D Thank you!
