I had just bought a Pi 2 and everything was working fine. I had it powered via my Macbook USB and was simply running a VNC client to do some basic work. I unplug the Pi and then go to boot it up again, and nothing. Both the red and green lights stayed on.
I booted my Zero up with the same card and it worked fine. I put a fresh install of Rasbian on another card and try the 2 again. Same issue, no response but the lights.
Then today, the same thing happened to my Zero. I unplugged it and then plugged it back in. The ACT light wouldn't go on.
Did a fresh install again and tried another card, nothing.
I should mention that at the time of reboot, each Pi was running at 100% for about 15 minutes, but was in a well-ventilated and rather cool room. I've tried 5 different SD cards and power supplies.
