timmoore46
Raspian 18th March edition - Help !
Sun May 15, 2016 8:29 pm
I have a 8MP camera fitted and have been enjoying getting to know its ways...but
when I turned it on (WiFi onboard latest Pi) it only got as par as the Terminal prompt , no GUI.
so I typed startx
After a long screen full of lines of code etc etc etc it came up with this:-
Fatal Server error:
(EE) Could not create lock file in /tmp/.tX0-lock
(EE)
(EE)
Please consult The X.org foudation support at htttp://wiki.X.org for help
(EE)
xinit: giving up
xinit: unable to connect to X Server:
Connection refused
xinit server error
xauth: error in locking authority file /home/pi/.Xauthority
____
Is the OS nuked ? Should I best Win32 image a fresh copy of Raspian.... : (((
Or is it recoverable ?
One error I made was I'd forgotten to attach the mouse also the keyboard. Could that have caused it ?
Any thought anyone ? I'm way out of my depth on how to fix this !
:cry: :cry: :cry:
Tim
Re: Raspian 18th March edition - Help !
Sun May 15, 2016 8:32 pm
Do NOT use sudo startx, ever it messes things up and makes you think the OS needs re-installing.
sudo rm /home/pi/.Xauthority; sudo reboot should fix all of your problems.
timmoore46
Sun May 15, 2016 8:54 pm
Alas it came back with
rm: cannot remove /home/pi/.Xauthority : Read-only file system
Many thanks for responding , greatly appreciated.
:cry: :cry: :cry:
Tim
Mon May 16, 2016 5:42 am
timmoore46 wrote: rm: cannot remove /home/pi/.Xauthority : Read-only file system
Get another SDCard and a USB SDCard reader. Build a "rescue" system on the new SDCard (Raspbian or NOOBS/Raspbian). Mount your SDCard with the read-only filesystem in the USB reader and see if you can repair it. If not see if you can retrieve your data and programs from that card.
timmoore46
Mon May 16, 2016 6:10 am
Many thanks for responding !
The certainty of me being able to achieve that is unknown... but I can re-image the SD card and rebuild the OS to the state it was before the difficulties is certain especially as I have a spare card in a working Pi B. so I can swap out..
How about chown ? Could I not alter the characteristics of the alleged faulty file ? Or is it a can of worms best left undisturbed?
Many thanks for your support !
Tim
Mon May 16, 2016 5:46 pm
Using chown may be a possibility, it depends how confident you are working with the Linux command line and whether we've identified the root cause of your problems.
timmoore46
Wed May 18, 2016 5:51 am
I'm ok with Bash but remembering the only error message one OS had was 'bdos error on A' meant it had a problem.......and nothing to do with A *.*
Quote...
'whether we've identified the root cause of your problems'
I'd be very surprised if that wasn't the case....
In the event I just started from scratch again. But stumbled into a strange problem loading VLC. I'm trying to get it to play video clips in MP4 / .h264 format and get the 30 fps right.
(I've got the latest 8MP camera attached) But the apt-get install vlc version of vlc isn't getting the fps right and I seem to remember there were variants possible, but I've not found reference to it again (should have made a note of it at the time ! *LOL*)
The version I had running before I nuked Raspian did the job nicely.
Nothing like a challenge *LOL*
Many thanks again for responding,
Tim
Return to “Raspberry Pi OS”
