_LLJY
exFAT sd card support?
Sun May 15, 2016 8:39 am
I just picked up a raspberry pi 3 and I was wondering if it supports exFAT for the SD card oh and is it possible to compile a 64bit android kernel with the pi3?
B.Goode
Re: exFAT sd card support?
Sun May 15, 2016 8:48 am
_LLJY wrote:I just picked up a raspberry pi 3 and I was wondering if it supports exFAT for the SD card
Need a closer definition of "supports exFAT for the SD card"
If the question is "can it boot from an exFAT partition on the SD card", the answer is NO.
Sun May 15, 2016 9:24 am
_LLJY wrote:I just picked up a raspberry pi 3 and I was wondering if it supports exFAT for the SD card oh and is it possible to compile a 64bit android kernel with the pi3?
Regards Android it is not natively supported, therefore AndroidPi has its own Community Forum: https://groups.google.com/forum/#!forum/android-rp
RPi 4B 4GB (SSD Boot)..
Dis93
Sun May 15, 2016 9:37 am
You managed to drop an i from that URL, fruitoftheloom.
https://groups.google.com/forum/#!forum/android-rpi
Sun May 15, 2016 9:55 am
Dis93 wrote:You managed to drop an i from that URL, fruitoftheloom.
:oops: Thanks..
drgeoff
Sun May 15, 2016 10:08 am
_LLJY wrote:I just picked up a raspberry pi 3 and I was wondering if it supports exFAT for the SD card......... ?
You can use cards which are 64 Gbyte or larger. Just write an image in the usual way. If you want to put NOOBS on an exFAT formatted card see viewtopic.php?f=91&t=83372&p=651745#p677748
_LLJY
Sun May 15, 2016 10:42 am
no im referring to compiling an android kernel WITH the pi not for it
drgeoff
Sun May 15, 2016 12:01 pm
It is possible.
But it does require the appropriate tools. Whether those exist or you can obtain them or make them is a different question.
Cancelor
Sun May 15, 2016 4:18 pm
Even if you can it would take a very long time. :x
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
Return to “Advanced users”
