[quote]
Quote from guru on November 26, 2011, 00:22
[quote]
Quote from ukscone on November 26, 2011, 00:20
[quote]
Quote from guru on November 26, 2011, 00:10
[quote]
Quote from radu on November 25, 2011, 19:24
Yes, but it says that on the Ethernet jack, not on the LAN Controller. If the A model won\'t include a LAN Controller, perhaps the image should be updated.[/quote]
I\'m with you now. Noted for the next revision
[/quote]
I won\'t say I told you so but i told you so
[/quote]
Yep. Couldn\'t see the wood for the trees
[/quote]
Must still say that it is a darn good \"visual aid\" though. It does explain things in \"words of one syllabul\" so that even I can understand it
