Sure that worked fine. I added another desktop and it worked like before. BUT when I logout of the desktop session or reboot then startx it is back to one desktop. It basically won't keep 2 desktops. It would be incredibly annoying if I had to do that every time I started a desktop session.Rive wrote:I can open and go to multiple desktops by clicking the mouse scroll
I still get "paste" and 'select all' when I right click
Malman35 wrote:I found another problem! I installed the new programs, Geany and sd-card copier and they aren't showing up in the menu (the one in the top right corner). They aren't showing up in the applications menu (the one found in the file manager on the left hand). I know there installed though cause I found them in /usr/share/applications and I ran both programs to. What is going on here
You mean like an F1 startx? (alt+ctrl+f1).. works for meMalman35 wrote:Sure that worked fine. I added another desktop and it worked like before. BUT when I logout of the desktop session or reboot then startx it is back to one desktop. It basically won't keep 2 desktops. It would be incredibly annoying if I had to do that every time I started a desktop session.Rive wrote:I can open and go to multiple desktops by clicking the mouse scroll
Well I can't really just restart!ShiftPlusOne wrote:It sounds like your sd card is corrupted or something else is messed up. A lot of what you're talking about hasn't been touched at all and wouldn't be any different from the previous release.
You could always restore your backup, which you of course have. Yes, there are way to restore defaults, but if your filesystem is corrupted, you're only seeing a symptom of a bigger problem.Malman35 wrote:Well I can't really just restart!ShiftPlusOne wrote:It sounds like your sd card is corrupted or something else is messed up. A lot of what you're talking about hasn't been touched at all and wouldn't be any different from the previous release.Is there a way I could restore the panel and desktop back to default. It wouldn't be that hard for me to make it back to the way I want it.
I do have a backup but it is from FebruaryShiftPlusOne wrote:You could always restore your backup, which you of course have. Yes, there are way to restore defaults, but if your filesystem is corrupted, you're only seeing a symptom of a bigger problem.Malman35 wrote:Well I can't really just restart!ShiftPlusOne wrote:It sounds like your sd card is corrupted or something else is messed up. A lot of what you're talking about hasn't been touched at all and wouldn't be any different from the previous release.Is there a way I could restore the panel and desktop back to default. It wouldn't be that hard for me to make it back to the way I want it.
rm -rf ~/.config/gtk-3.0/gtk.css ~/.config/Trolltech.conf ~/.config/pcmanfm/LXDE-pi ~/.config/lxsession/LXDE-pi/desktop.conf ~/.themes/PiX ~/.config/openbox/lxde-pi-rc.xml ~/.config/lxpanel/LXDE-pi
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install --reinstall raspberrypi-ui-mods.
Well some things are fixed.ShiftPlusOne wrote:I don't know the state of your filesystem or what you want to achieve exactly. The main problem is that most of what's broken for you is stuff that hasn't been touched by this update at all.
Try this:This will remove all the custom stuff from your home directory. Make sure your packages are up to date and then reinstall customisations, in case those files are corrupted. When you restart, those files will be copied into your home directory again. It won't restore it to how it was before the update, but it should make sure the ui-related changes are correct. If your filesystem is corrupted, there are no guarantees that anything will work as it should.Code: Select all
rm -rf ~/.config/gtk-3.0/gtk.css ~/.config/Trolltech.conf ~/.config/pcmanfm/LXDE-pi ~/.config/lxsession/LXDE-pi/desktop.conf ~/.themes/PiX ~/.config/openbox/lxde-pi-rc.xml ~/.config/lxpanel/LXDE-pi sudo apt-get update sudo apt-get dist-upgrade sudo apt-get install --reinstall raspberrypi-ui-mods.
It also won't help you with your desktop background issue because it was also not touched by the recent updates. You'll need to figure out why that's not displaying on your own. It kind of sounds like pcmanfm desktop and maybe even openbox isn't running. Maybe there's something insightful in logs like ~/.cache/lxsession/LXDE-pi/run.log or ~/.cache/openbox/openbox.log
First I removed ~/.cache/menus usingShiftPlusOne wrote:There is a utility called 'debsums' which might help you. Install it and read the manpage for it.
Also, try deleting ~/.cache/menus
sudo rm -r ~/.cache/menus
Okay that is great but uh how do I use debsums to check that stuff and how can I tell what needs to be reinstalledShiftPlusOne wrote:It should tell you which files may have been corrupted.
So it seems like your menu was using the cached version of applications and that's why the new ones weren't displayed. For whatever reason, it's not checking the applications again. This isn't something we would've touched, so the problem is elsewhere. Debsums may help you find out which packages you need to re-install.
Sorry, I can't make it clearer than the manpage and a set of google queries for the specific parts you don't get. Also dpkg's -S flag or apt-file would be useful too.Malman35 wrote:Okay that is great but uh how do I use debsums to check that stuff and how can I tell what needs to be reinstalledShiftPlusOne wrote:It should tell you which files may have been corrupted.
pi@malman ~ $ sudo debsums -s -e
debsums: changed file /etc/skel/.bashrc (from bash package)
debsums: missing file /etc/default/chromium-browser (from chromium-browser package)
debsums: changed file /etc/dphys-swapfile (from dphys-swapfile package)
debsums: changed file /etc/fb.modes (from fbset package)
debsums: changed file /etc/default/rcS (from initscripts package)
debsums: changed file /etc/lightdm/lightdm.conf (from lightdm package)
debsums: changed file /etc/lightdm/lightdm-gtk-greeter.conf (from lightdm-gtk-greeter package)
debsums: changed file /etc/login.defs (from login package)
debsums: changed file /etc/xdg/pcmanfm/LXDE/pcmanfm.conf (from lxde-common package)
debsums: changed file /etc/xdg/lxsession/LXDE/desktop.conf (from lxde-common package)
debsums: changed file /etc/xdg/openbox/LXDE/rc.xml (from lxde-common package)
debsums: changed file /etc/default/useradd (from passwd package)
debsums: changed file /etc/sysctl.conf (from procps package)
debsums: changed file /etc/sudoers (from sudo package)
pi@malman ~ $
That looks roughly like what I'd expect, so that's promising.Malman35 wrote:I don't know exactly what Im looking for but would this be a clue.If this is what I'm looking for then I have no clue what to do next. Thanks again for your time.Code: Select all
pi@malman ~ $ sudo debsums -s -e debsums: changed file /etc/skel/.bashrc (from bash package) debsums: missing file /etc/default/chromium-browser (from chromium-browser package) debsums: changed file /etc/dphys-swapfile (from dphys-swapfile package) debsums: changed file /etc/fb.modes (from fbset package) debsums: changed file /etc/default/rcS (from initscripts package) debsums: changed file /etc/lightdm/lightdm.conf (from lightdm package) debsums: changed file /etc/lightdm/lightdm-gtk-greeter.conf (from lightdm-gtk-greeter package) debsums: changed file /etc/login.defs (from login package) debsums: changed file /etc/xdg/pcmanfm/LXDE/pcmanfm.conf (from lxde-common package) debsums: changed file /etc/xdg/lxsession/LXDE/desktop.conf (from lxde-common package) debsums: changed file /etc/xdg/openbox/LXDE/rc.xml (from lxde-common package) debsums: changed file /etc/default/useradd (from passwd package) debsums: changed file /etc/sysctl.conf (from procps package) debsums: changed file /etc/sudoers (from sudo package) pi@malman ~ $
pi@malman ~ $ sudo debsums -s -a
pi@malman ~ $
I have a background picture. That worked fine. Please see pics for better explanationShiftPlusOne wrote: So what are the remaining problems? No desktop background and an empty menu?
<desktops>
<!-- this stuff is only used at startup, pagers allow you to change them
during a session
these are default values to use when other ones are not already set
by other applications, or saved in your session
use obconf if you want to change these without having to log out
and back in -->
<number>1</number>ShiftPlusOne wrote:What does /etc/xdg/menus/lxde-pi-applications.menu look like?
<!DOCTYPE Menu PUBLIC "-//freedesktop//DTD Menu 1.0//EN"
"http://www.freedesktop.org/standards/menu-spec/1.0/menu.dtd">
<Menu>
<Name>Applications</Name>
<Directory>lxde-menu-applications.directory</Directory>
<!-- Read standard .directory and .desktop file locations -->
<DefaultAppDirs/>
<DefaultDirectoryDirs/>
<!-- Read in overrides and child menus from applications-merged/ -->
<DefaultMergeDirs/>
<!-- Accessories submenu -->
<Menu>
<Name>Accessories</Name>
<Directory>lxde-utility.directory</Directory>
<Include>
<And>
<Category>Utility</Category>
<!-- Accessibility spec must have either the Utility or Settings
category, and we display an accessibility submenu already for
the ones that do not have Settings, so don't display accessibility
applications here -->
<Not><Category>Accessibility</Category></Not>
<Not><Category>System</Category></Not>
</And>
</Include>
</Menu> <!-- End Accessories -->
<!-- Accessibility submenu -->
<Menu>
<Name>Universal Access</Name>
<Directory>lxde-utility-accessibility.directory</Directory>
<Include>
<And>
<Not><Category>Settings</Category></Not>
</And>
</Include>
</Menu> <!-- End Accessibility -->
<!-- Development Tools -->
<Menu>
<Name>Development</Name>
<Directory>lxde-development.directory</Directory>
<Include>
<And>
<Category>Development</Category>
</And>
<Filename>emacs.desktop</Filename>
</Include>
</Menu> <!-- End Development Tools -->
<!-- Education -->
<Menu>
<Name>Education</Name>
<Directory>lxde-education.directory</Directory>
<Include>
<And>
<Category>Education</Category>
</And>
</Include>
</Menu> <!-- End Education -->
<!-- Games -->
<Menu>
<Name>Games</Name>
<Directory>lxde-game.directory</Directory>
<Include>
<And>
<Category>Game</Category>
</And>
</Include>
</Menu> <!-- End Games -->
<!-- Graphics -->
<Menu>
<Name>Graphics</Name>
<Directory>lxde-graphics.directory</Directory>
<Include>
<And>
<Category>Graphics</Category>
<Not><Category>Utility</Category></Not>
</And>
</Include>
</Menu> <!-- End Graphics -->
<!-- Internet -->
<Menu>
<Name>Internet</Name>
<Directory>lxde-network.directory</Directory>
<Include>
<And>
<Category>Network</Category>
</And>
</Include>
</Menu> <!-- End Internet -->
<!-- Multimedia -->
<Menu>
<Name>Multimedia</Name>
<Directory>lxde-audio-video.directory</Directory>
<Include>
<And>
<Category>AudioVideo</Category>
</And>
</Include>
</Menu> <!-- End Multimedia -->
<!-- Office -->
<Menu>
<Name>Office</Name>
<Directory>lxde-office.directory</Directory>
<Include>
<And>
<Category>Office</Category>
</And>
</Include>
</Menu> <!-- End Office -->
<!-- System Tools-->
<Menu>
<Name>System</Name>
<Directory>lxde-system-tools.directory</Directory>
<Include>
<And>
<Not><Category>PackageManager</Category></Not>
</And>
</Include>
</Menu> <!-- End System Tools -->
<!-- Other -->
<Menu>
<Name>Other</Name>
<Directory>lxde-other.directory</Directory>
<OnlyUnallocated/>
<Include>
<And>
<Not><Category>Core</Category></Not>
<Not><Category>Screensaver</Category></Not>
</And>
</Include>
</Menu> <!-- End Other -->
<!-- Help -->
<Menu>
<Name>Help</Name>
<Directory>lxde-help.directory</Directory>
<Include>
<And>
<Category>Help</Category>
</And>
</Include>
<Menu>
<Name>DesktopSettings</Name>
<Directory>lxde-settings.directory</Directory>
<OnlyUnallocated/>
<Include>
<Or>
</Or>
</Include>
<Layout>
<Merge type="menus"/>
<Merge type="files"/>
</Layout>
</Menu> <!-- End Settings -->
<Layout>
<Menuname>Development</Menuname>
<Menuname>Office</Menuname>
<Menuname>Internet</Menuname>
<Menuname>Games</Menuname>
<Menuname>Other</Menuname>
<Menuname>Accessories</Menuname>
<Separator/>
<Menuname>Help</Menuname>
<Separator/>
<Menuname>DesktopSettings</Menuname>
</Layout>
</Menu> <!-- End Applications -->
ShiftPlusOne wrote:Could you also try deleting the menu cache again
rm: cannot remove ‘/home/pi/.cache/menus’: No such file or directory
There was absolutely no change in the menus. Nothing happenedShiftPlusOne wrote:also ~/.local/share/applications/* and ~/.local/share/desktop-directories/*
Awesome!ShiftPlusOne wrote:In ~/.config/openbox/lxde-pi-rc.xml, look for this:
CODE: SELECT ALL
<desktops>
during a session
and back in -->
<number>1</number>
Change number to however many desktops you need, log out and back in. Alternatively, install obconf and use that to make the change.
ShiftPlusOne wrote:Could you post the output of 'export'?
pi@malman ~ $ export
declare -x DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-n68hsVPLgC,guid=57d2b673856030a4dcf218ca5739af4d"
declare -x DESKTOP_SESSION="LXDE-pi"
declare -x DISPLAY=":0.0"
declare -x HOME="/home/pi"
declare -x HUSHLOGIN="FALSE"
declare -x LANG="en_GB.UTF-8"
declare -x LOGNAME="pi"
declare -x LS_COLORS="rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:"
declare -x MAIL="/var/mail/pi"
declare -x OLDPWD
declare -x PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games"
declare -x PWD="/home/pi"
declare -x SAL_USE_VCLPLUGIN="gtk"
declare -x SHELL="/bin/bash"
declare -x SHLVL="2"
declare -x SSH_AGENT_PID="8618"
declare -x SSH_AUTH_SOCK="/tmp/ssh-DPHbUJro9THq/agent.8594"
declare -x TERM="xterm"
declare -x USER="pi"
declare -x WINDOWPATH="1"
declare -x XAUTHORITY="/home/pi/.Xauthority"
declare -x XDG_CONFIG_DIRS="/etc/xdg"
declare -x XDG_CONFIG_HOME="/home/pi/.config"
declare -x XDG_CURRENT_DESKTOP="LXDE"
declare -x XDG_DATA_DIRS="/usr/local/share:/usr/share/raspi-ui-overrides:/usr/share:/usr/share/gdm:/var/lib/menu-xdg"
declare -x XDG_MENU_PREFIX="lxde-pi-"
declare -x XDG_RUNTIME_DIR="/run/user/1000"
declare -x XDG_SEAT="seat0"
declare -x XDG_SESSION_ID="c1"
declare -x XDG_VTNR="1"
declare -x _LXSESSION_PID="8594"
pi@malman ~ $
