Dis93
How to is file system has errors.. and how to clean them
Fri May 13, 2016 8:01 pm
I noticed on boot my Zero had a dirty bit set (dirty..dirty..dirty bit)
I ran fsck -n which removed the dirty bit but but obviously didn't check or repair my sd card.
So how does one;
a - check to see if the filesystem needs repair
b - repair the system
I know you can't fully repair a live system so what do you do? In the case of a Pi, if you have another Pi can you use a USB sd card reader and scan the system? Can you scan and repair the sd card via an sd card reader on a *nix/Mac/Win box?
I did try and search the forum for this, but grief me if this question is obvious to a greybeard :P
Dis93
Re: How to is file system has errors.. and how to clean them
Fri May 13, 2016 8:02 pm
OMG.. title gore.. should have been How to see if the file system has errors.. and how to clean them.
CarlRJ
Sat May 14, 2016 12:11 am
Do this:
sudo touch /forcefsck
And the next time you reboot, the filesystem will get fsck'd before it gets mounted.
Dis93
Sat May 14, 2016 8:52 am
Thank you!
I knew it'd be something simple :)
