davenull
external SD in a USB card reader: which path?
Fri May 13, 2016 3:57 pm
hi,
I had just copied my internal SD to an external SD card in a USB card reader by the new SD copy feature:
which is the path to it?
I can't find it to check the contents! :evil:
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
thagrol
Re: external SD in a USB card reader: which path?
Fri May 13, 2016 4:25 pm
Can you remember what you selected for "Copy to device"?
ls <copy to device>*
should give you a list of device and partitions.
mount
will tell you whether they're mounted and where.
If they're not mounted, they can be mounted one at a time by
sudo mount <copy to device><n> /mnt
e.g.
sudo mount /dev/sda1 /mnt
Don't forget to
sudo umount /mnt
between mounts and before removing the SD card.
If you can't remember what you selected try
ls /dev/sd*
and make your best guess from its output.
davenull
Fri May 13, 2016 4:26 pm
there was just 1 option:
/dev/sda
davenull
the file /dev/sda exists, but no sda1 sda2 sda5 sda6 sda7...
davenull
Fri May 13, 2016 4:28 pm
sudo fdisk -l /dev/sda
shows
Disk /dev/sda: 29,7 GiB, 31914983424 bytes, 62333952 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
gordon77
With file manager, under X, does it show under /media ?
FTrevorGowen
IIRC, it's "below" /media/pi (two entries, one for "boot" and another, with a hex UID string for the remainder of the filesystem)
Trev.
davenull
Fri May 13, 2016 4:32 pm
/media/pi is empty
davenull
Fri May 13, 2016 4:48 pm
now I have done that procedure the 2nd time and I now can see a folder
/media/pi/...(no subdirectories???).../2F0-BD44,
/3225-7E2C
/6330625andamillionmorechars
/Datenträger31GB
where can I see now the contents of my copied SD?
hell, is that weird!
davenull
Fri May 13, 2016 4:53 pm
aaah -
beyond /dev there are now
sda,
sda1,
sda2,
(no sda3, no sda4),
sda5,
sda6,
sda7
so what does that mean?
davenull
Fri May 13, 2016 6:55 pm
update:
thanks to a detailed assistance by procount I now have got some introduction and overview about the disk, partition, and path architectures.
I now can mount a copied drive and even check single folders of the original and the copied SD card , e.g. by diff.
That is now really a lot for the start. Now I will try to test the copied SD on a 2nd Pi board during the weekend.
Thanks to all, and especially to procount, for your help!
