ffel
Long response time after moving root fs to USB flash drive
Thu May 12, 2016 8:23 pm
Hello there!
A few days ago I moved my root filesystem to an USB flash drive because I was told it would be more failsafe and the OS would possibly be quicker and 'snappier'.
But instead it has dramatically slowed down: When executing programs or shell-scripts (from the shell) the Pi does not react for a few seconds. It is the same when using autocompletion (tab), it takes 3-6 seconds before anything happens.
Is there anybody who can help me? I don't want to be forced to move the root filesystem back to the sd card because I use the pi as a cloud server and I need the space that I purchased with the flash drive.
Greetings and thanks in advance, ffel
Here is some information about my setup:
-A Raspberry Pi 2 Model B
-A Data Traveler SE9 USB2.0 flash drive from Kingston with 64 GB's of space (DTSE9H/64GB) [Manufacturer id from lsusb: ID 0951:1665]
-A no-name 1GB sd card for the boot partition
-/boot/cmdline.txt:
... rootdelay=5 ...
-/boot/config.txt:
max_usb_current=1
-/etc/fstab entry
/dev/sda1       /               ext4    defaults,noatime  0       1
MaxK1
Re: Long response time after moving root fs to USB flash dri
Fri May 13, 2016 8:41 am
Please post the output from dmesg. It may show something "interesting"... like USB resets. Do you ever see a multi-colored square in the top right corner of the screen or the power light (red LED) blinking?
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
Aydan
Fri May 13, 2016 8:46 am
Well, it could be that you USB stick has really bad random access performance, which slows down your system.
IF you have a windows system at hand you can use Crystaldiskmark to check performance. You'll need to have a NTFS or FAT partition of sufficient size on it though.
For your use case you don't need the root filesystem on USB, just mount your stick as storage for your cloud service.
Regards
Aydan
MaxK1
Fri May 13, 2016 9:34 am
Or run hdparm --direct -Tt /dev/sda This is a non-destructive test that reads the "raw" device (ie it doesn't care what filesystem is on the device). Then run the same again with /dev/mmcblk0 and see how the numbers compare.
ffel
Fri May 13, 2016 10:45 pm
Thanks for your fast responses and sorry that I could not reply earlier.
@MaxK1: Here is my dmesg-output
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.1.19-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #858 SMP Tue Mar 15 15:56:00 GMT 2016
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[    0.000000] cma: Reserved 8 MiB at 0x36400000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 225280
[    0.000000] free_area_init_node: node 0, pgdat 80880fc0, node_mem_map b5c44000
[    0.000000]   Normal zone: 1980 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 225280 pages, LIFO batch:31
[    0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[    0.000000] [bcm2709_smp_init_cpus] ncores=4
[    0.000000] PERCPU: Embedded 12 pages/cpu @b6fb1000 s20416 r8192 d20544 u49152
[    0.000000] pcpu-alloc: s20416 r8192 d20544 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 223300
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa01041 bcm2709.serial=0xdae59323 smsc95xx.macaddr=B8:27:EB:E5:93:23 bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/sda1 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait rootdelay=5
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 874420K/901120K available (6064K kernel code, 534K rwdata, 1664K rodata, 444K init, 757K bss, 18508K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xb7800000 - 0xff000000   (1144 MB)
    lowmem  : 0x80000000 - 0xb7000000   ( 880 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x807945f0   (7730 kB)
      .init : 0x80795000 - 0x80804000   ( 444 kB)
      .data : 0x80804000 - 0x80889b10   ( 535 kB)
       .bss : 0x8088c000 - 0x809497dc   ( 758 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:608
[    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000012] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000033] Switching to timer-based delay loop, resolution 52ns
[    0.000317] Console: colour dummy device 80x30
[    0.001530] console [tty1] enabled
[    0.001587] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001665] pid_max: default: 32768 minimum: 301
[    0.002054] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002106] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003382] Initializing cgroup subsys blkio
[    0.003454] Initializing cgroup subsys memory
[    0.003512] Initializing cgroup subsys devices
[    0.003562] Initializing cgroup subsys freezer
[    0.003627] Initializing cgroup subsys net_cls
[    0.003726] CPU: Testing write buffer coherency: ok
[    0.003836] ftrace: allocating 20313 entries in 60 pages
[    0.053104] CPU0: update cpu_capacity 1024
[    0.053179] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.053220] [bcm2709_smp_prepare_cpus] enter
[    0.053377] Setting up static identity map for 0x8240 - 0x8274
[    0.055909] [bcm2709_boot_secondary] cpu:1 started (0) 18
[    0.056351] [bcm2709_secondary_init] enter cpu:1
[    0.056410] CPU1: update cpu_capacity 1024
[    0.056419] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.057007] [bcm2709_boot_secondary] cpu:2 started (0) 18
[    0.057364] [bcm2709_secondary_init] enter cpu:2
[    0.057396] CPU2: update cpu_capacity 1024
[    0.057405] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.057949] [bcm2709_boot_secondary] cpu:3 started (0) 18
[    0.058204] [bcm2709_secondary_init] enter cpu:3
[    0.058235] CPU3: update cpu_capacity 1024
[    0.058243] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.058332] Brought up 4 CPUs
[    0.058443] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.058476] CPU: All CPU(s) started in HYP mode.
[    0.058505] CPU: Virtualization extensions available.
[    0.059554] devtmpfs: initialized
[    0.083300] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.083649] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.084836] pinctrl core: initialized pinctrl subsystem
[    0.085647] NET: Registered protocol family 16
[    0.091364] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.092655] bcm2709.uart_clock = 3000000
[    0.097503] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.097562] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.097783] Serial: AMBA PL011 UART driver
[    0.098002] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[    0.599394] console [ttyAMA0] enabled
[    0.603653] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.678407] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[    0.687142] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[    0.695531] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[    0.702447] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[    0.708404] SCSI subsystem initialized
[    0.712411] usbcore: registered new interface driver usbfs
[    0.718038] usbcore: registered new interface driver hub
[    0.723510] usbcore: registered new device driver usb
[    0.729280] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-15 14:51
[    0.764870] Switched to clocksource arch_sys_counter
[    0.818768] FS-Cache: Loaded
[    0.822040] CacheFiles: Loaded
[    0.836423] NET: Registered protocol family 2
[    0.842070] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.849308] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.855974] TCP: Hash tables configured (established 8192 bind 8192)
[    0.862478] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.868498] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.875355] NET: Registered protocol family 1
[    0.880147] RPC: Registered named UNIX socket transport module.
[    0.886138] RPC: Registered udp transport module.
[    0.890857] RPC: Registered tcp transport module.
[    0.895594] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.903321] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.912872] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.935229] VFS: Disk quotas dquot_6.6.0
[    0.939554] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.949165] FS-Cache: Netfs 'nfs' registered for caching
[    0.955769] NFS: Registering the id_resolver key type
[    0.960900] Key type id_resolver registered
[    0.965141] Key type id_legacy registered
[    0.972026] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.979685] io scheduler noop registered
[    0.983640] io scheduler deadline registered (default)
[    0.989148] io scheduler cfq registered
[    0.995656] BCM2708FB: allocated DMA memory f6800000
[    1.000694] BCM2708FB: allocated DMA channel 0 @ f3007000
[    1.011768] Console: switching to colour frame buffer device 82x26
[    1.023183] Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
[    1.032482] vc-cma: Videocore CMA driver
[    1.038116] vc-cma: vc_cma_base      = 0x00000000
[    1.044487] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.051509] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.058678] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    1.085719] brd: module loaded
[    1.099278] loop: module loaded
[    1.104960] vchiq: vchiq_init_state: slot_zero = 0xb6880000, is_master = 0
[    1.115195] Loading iSCSI transport class v2.0-870.
[    1.122545] usbcore: registered new interface driver smsc95xx
[    1.129965] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.337649] Core Release: 2.80a
[    1.342251] Setting default values for core params
[    1.348579] Finished setting default values for core params
[    1.556109] Using Buffer DMA mode
[    1.560924] Periodic Transfer Interrupt Enhancement - disabled
[    1.568318] Multiprocessor Interrupt Enhancement - disabled
[    1.575483] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.581387] Dedicated Tx FIFOs mode
[    1.586753] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xb6814000 dma = 0xf6814000 len=9024
[    1.599770] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[    1.622881] dwc_otg: Microframe scheduler enabled
[    1.622957] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80417288
[    1.630489] WARN::hcd_init_fiq:413: FIQ ASM at 0x804175f8 length 36
[    1.638380] WARN::hcd_init_fiq:438: MPHI regs_base at 0xb789a000
[    1.645995] dwc_otg 3f980000.usb: DWC OTG Controller
[    1.652549] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    1.661501] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[    1.668698] Init: Port Power? op_state=1
[    1.674145] Init: Power Port (0)
[    1.679146] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.687532] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.696339] usb usb1: Product: DWC OTG Controller
[    1.702577] usb usb1: Manufacturer: Linux 4.1.19-v7+ dwc_otg_hcd
[    1.710148] usb usb1: SerialNumber: 3f980000.usb
[    1.717201] hub 1-0:1.0: USB hub found
[    1.722510] hub 1-0:1.0: 1 port detected
[    1.728435] dwc_otg: FIQ enabled
[    1.728448] dwc_otg: NAK holdoff enabled
[    1.728458] dwc_otg: FIQ split-transaction FSM enabled
[    1.728497] Module dwc_common_port init
[    1.728904] usbcore: registered new interface driver usb-storage
[    1.736690] mousedev: PS/2 mouse device common for all mice
[    1.744536] bcm2835-cpufreq: min=600000 max=900000
[    1.751162] sdhci: Secure Digital Host Controller Interface driver
[    1.758884] sdhci: Copyright(c) Pierre Ossman
[    1.765143] sdhost: log_buf @ b6813000 (f6813000)
[    1.844914] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    1.852341] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.880303] ledtrig-cpu: registered to indicate activity on CPUs
[    1.888215] hidraw: raw HID events driver (C) Jiri Kosina
[    1.895444] usbcore: registered new interface driver usbhid
[    1.902568] usbhid: USB HID core driver
[    1.908470] Initializing XFRM netlink socket
[    1.914326] NET: Registered protocol family 17
[    1.920504] Key type dns_resolver registered
[    1.925032] Indeed it is in host mode hprt0 = 00021501
[    1.932098] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.932193] mmc0: new SD card at address e624
[    1.934984] mmcblk0: mmc0:e624 SU01G 969 MiB
[    1.956363] Registering SWP/SWPB emulation handler
[    1.963743] registered taskstats version 1
[    1.964255]  mmcblk0: p1
[    1.973764] vc-sm: Videocore shared memory driver
[    1.980028] [vc_sm_connected_init]: start
[    1.986289] [vc_sm_connected_init]: end - returning 0
[    1.994244] Waiting 5 sec before mounting root device...
[    2.094912] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.103066] Indeed it is in host mode hprt0 = 00001101
[    2.305255] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.313528] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.323091] hub 1-1:1.0: USB hub found
[    2.328520] hub 1-1:1.0: 5 ports detected
[    2.614905] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.735224] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.743707] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.755444] smsc95xx v1.0.4
[    2.818998] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:e5:93:23
[    3.064905] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[    3.276690] usb 1-1.2: New USB device found, idVendor=0951, idProduct=1665
[    3.285293] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.294307] usb 1-1.2: Product: DataTraveler 2.0
[    3.300644] usb 1-1.2: Manufacturer: Kingston
[    3.306705] usb 1-1.2: SerialNumber: AC220B2806671030494E0942
[    3.315449] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[    3.324075] scsi host0: usb-storage 1-1.2:1.0
[    4.326982] scsi 0:0:0:0: Direct-Access     Kingston DataTraveler 2.0 0000 PQ: 0 ANSI: 4
[    4.341412] sd 0:0:0:0: [sda] 121063488 512-byte logical blocks: (62.0 GB/57.7 GiB)
[    4.354537] sd 0:0:0:0: [sda] Write Protect is off
[    4.361181] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[    4.362992] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    4.384431]  sda: sda1
[    4.395162] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    7.032911] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    7.044356] VFS: Mounted root (ext4 filesystem) readonly on device 8:1.
[    7.054682] devtmpfs: mounted
[    7.060251] Freeing unused kernel memory: 444K (80795000 - 80804000)
[    7.362832] random: systemd urandom read with 99 bits of entropy available
[    7.376482] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    7.394346] systemd[1]: Detected architecture 'arm'.
[    7.510840] NET: Registered protocol family 10
[    7.519277] systemd[1]: Inserted module 'ipv6'
[    7.530216] systemd[1]: Set hostname to <raspberrypi>.
[    7.591716] uart-pl011 3f201000.uart: no DMA platform data
[    7.971987] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    7.983971] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.995624] systemd[1]: Expecting device dev-ttyAMA0.device...
[    8.006021] systemd[1]: Starting Remote File Systems (Pre).
[    8.015888] systemd[1]: Reached target Remote File Systems (Pre).
[    8.024076] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    8.039472] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.052851] systemd[1]: Starting Encrypted Volumes.
[    8.062163] systemd[1]: Reached target Encrypted Volumes.
[    8.069709] systemd[1]: Starting Swap.
[    8.077847] systemd[1]: Reached target Swap.
[    8.084156] systemd[1]: Expecting device dev-mmcblk0p1.device...
[    8.094458] systemd[1]: Starting Root Slice.
[    8.102952] systemd[1]: Created slice Root Slice.
[    8.109601] systemd[1]: Starting User and Session Slice.
[    8.119157] systemd[1]: Created slice User and Session Slice.
[    8.126840] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    8.137686] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    8.146598] systemd[1]: Starting Delayed Shutdown Socket.
[    8.156055] systemd[1]: Listening on Delayed Shutdown Socket.
[    8.163557] systemd[1]: Starting Journal Socket (/dev/log).
[    8.173182] systemd[1]: Listening on Journal Socket (/dev/log).
[    8.180955] systemd[1]: Starting udev Control Socket.
[    8.189983] systemd[1]: Listening on udev Control Socket.
[    8.197251] systemd[1]: Starting udev Kernel Socket.
[    8.206154] systemd[1]: Listening on udev Kernel Socket.
[    8.213303] systemd[1]: Starting Journal Socket.
[    8.221974] systemd[1]: Listening on Journal Socket.
[    8.228874] systemd[1]: Starting System Slice.
[    8.237418] systemd[1]: Created slice System Slice.
[    8.244139] systemd[1]: Starting File System Check on Root Device...
[    8.257615] systemd[1]: Starting system-systemd\x2dfsck.slice.
[    8.268355] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    8.276739] systemd[1]: Starting system-getty.slice.
[    8.286334] systemd[1]: Created slice system-getty.slice.
[    8.293542] systemd[1]: Starting system-serial\x2dgetty.slice.
[    8.299615] random: nonblocking pool is initialized
[    8.310321] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    8.318619] systemd[1]: Starting Increase datagram queue length...
[    8.332018] systemd[1]: Starting Restore / save the current clock...
[    8.351863] systemd[1]: Mounted Huge Pages File System.
[    8.359816] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    8.380917] systemd[1]: Mounting Debug File System...
[    8.441343] systemd[1]: Starting Load Kernel Modules...
[    8.456128] systemd[1]: Starting udev Coldplug all Devices...
[    8.471005] systemd[1]: Mounting POSIX Message Queue File System...
[    8.515679] systemd[1]: Started Set Up Additional Binary Formats.
[    8.523964] systemd[1]: Starting Slices.
[    8.531606] fuse init (API version 7.23)
[    8.538672] systemd[1]: Reached target Slices.
[    8.544961] i2c /dev entries driver
[    8.556519] systemd[1]: Mounted POSIX Message Queue File System.
[    8.567278] systemd[1]: Mounted Debug File System.
[    8.578503] systemd[1]: Started Increase datagram queue length.
[    8.600954] systemd[1]: Started Restore / save the current clock.
[    8.612678] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    8.629649] systemd[1]: Started Load Kernel Modules.
[    8.660091] systemd[1]: Time has been changed
[    8.717218] systemd[1]: Started udev Coldplug all Devices.
[    8.840846] systemd[1]: Mounting FUSE Control File System...
[    8.854129] systemd[1]: Starting Apply Kernel Variables...
[    8.868802] systemd[1]: Mounting Configuration File System...
[    8.882797] systemd[1]: Starting Create Static Device Nodes in /dev...
[    8.898181] systemd[1]: Starting Syslog Socket.
[    8.907663] systemd[1]: Listening on Syslog Socket.
[    8.914522] systemd[1]: Starting Journal Service...
[    8.929335] systemd[1]: Started Journal Service.
[   11.358825] systemd-udevd[112]: starting version 215
[   11.850548] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[   12.237170] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   12.657552] EXT4-fs (sda1): re-mounted. Opts: (null)
[   12.922668] bcm2835-rng 3f104000.rng: hwrng registered
[   13.180492] systemd-journald[108]: Received request to flush runtime journal from PID 1
[   14.041284] cfg80211: Calling CRDA to update world regulatory domain
[   14.438504] Adding 1048572k swap on /var/swap.  Priority:-1 extents:88 across:50651132k FS
[   15.966045] cfg80211: World regulatory domain updated:
[   15.966073] cfg80211:  DFS Master region: unset
[   15.966083] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   15.966096] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   15.966107] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   15.966118] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   15.966131] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   15.966143] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   15.966154] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   15.966164] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   15.966175] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   31.797063] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   31.797279] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   33.208524] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   33.212305] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
I can't tell you whether there is this colored square on my screen because I have only ssh access now. But I know that the red LED is on continuously and I have not seen it blinking since I got a propper power supply.
@Aydan + @ MaxK1: The result of the latter test:
/dev/sda:
 Timing O_DIRECT cached reads:    54 MB in  2.02 seconds =  26.78 MB/sec
 Timing O_DIRECT disk reads:  38 MB in  3.06 seconds =  12.40 MB/sec
/dev/mmcblk0:
 Timing O_DIRECT cached reads:    24 MB in  2.13 seconds =  11.26 MB/sec
 Timing O_DIRECT disk reads:  34 MB in  3.02 seconds =  11.27 MB/sec
I think those numbers are quite how you would expect them, aren't they?
Thanks for helping me out, ffel
MaxK1
Sat May 14, 2016 8:16 am
Times look about right, so what else is going on? Could you post the output from 'ps ax' and 'free'? Something is either eating all 4 cores or memory methinks... Or else your network is causing your ssh session to crawl.
What kernel are you running 'uname -a' and have you updated/upgraded? (apt-get update && apt-get upgrade)
ffel
Sat May 14, 2016 10:17 am
ps ax output
 ps ax
  PID TTY      STAT   TIME COMMAND
    1 ?        Ss     0:23 /sbin/init
    2 ?        S      0:00 [kthreadd]
    3 ?        S      0:04 [ksoftirqd/0]
    5 ?        S<     0:00 [kworker/0:0H]
    7 ?        S      0:24 [rcu_sched]
    8 ?        S      0:00 [rcu_bh]
    9 ?        S      0:00 [migration/0]
   10 ?        S      0:00 [migration/1]
   11 ?        S      0:01 [ksoftirqd/1]
   13 ?        S<     0:00 [kworker/1:0H]
   14 ?        S      0:00 [migration/2]
   15 ?        S      0:00 [ksoftirqd/2]
   17 ?        S<     0:00 [kworker/2:0H]
   18 ?        S      0:00 [migration/3]
   19 ?        S      0:01 [ksoftirqd/3]
   21 ?        S<     0:00 [kworker/3:0H]
   22 ?        S<     0:00 [khelper]
   23 ?        S      0:00 [kdevtmpfs]
   24 ?        S<     0:00 [netns]
   25 ?        S<     0:00 [perf]
   26 ?        S      0:00 [khungtaskd]
   27 ?        S<     0:00 [writeback]
   28 ?        S<     0:00 [crypto]
   29 ?        S<     0:00 [bioset]
   30 ?        S<     0:00 [kblockd]
   32 ?        S<     0:00 [rpciod]
   33 ?        S      0:00 [kswapd0]
   34 ?        S      0:00 [fsnotify_mark]
   35 ?        S<     0:00 [nfsiod]
   41 ?        S<     0:00 [kthrotld]
   43 ?        S<     0:00 [VCHIQ-0]
   44 ?        S<     0:00 [VCHIQr-0]
   45 ?        S<     0:00 [VCHIQs-0]
   46 ?        S<     0:00 [iscsi_eh]
   47 ?        S<     0:00 [dwc_otg]
   48 ?        S<     0:00 [DWC Notificatio]
   51 ?        S      0:00 [mmcqd/0]
   52 ?        S      0:00 [VCHIQka-0]
   53 ?        S<     0:00 [SMIO]
   54 ?        S<     0:00 [deferwq]
   57 ?        S      0:00 [scsi_eh_0]
   58 ?        S<     0:00 [scsi_tmf_0]
   59 ?        S      0:15 [usb-storage]
   61 ?        S<     0:00 [kworker/1:1H]
   62 ?        S      0:04 [jbd2/sda1-8]
   63 ?        S<     0:00 [ext4-rsv-conver]
   64 ?        S<     0:00 [ipv6_addrconf]
  108 ?        Ss     0:03 /lib/systemd/systemd-journald
  112 ?        Ss     0:00 /lib/systemd/systemd-udevd
  378 ?        Ss     0:00 /usr/sbin/cron -f
  390 ?        Ss     0:01 /lib/systemd/systemd-logind
  391 ?        Ss     0:00 avahi-daemon: running [raspberrypi.local]
  393 ?        Ss     0:01 /usr/bin/dbus-daemon --system --address=systemd: --nof
  417 ?        Ss     0:01 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/tr
  423 ?        S<     0:00 [cfg80211]
  425 ?        Ss     0:00 /sbin/dhcpcd -q -b
  432 ?        S<     0:00 [kworker/2:1H]
  433 ?        S      0:00 avahi-daemon: chroot helper
  436 ?        S<     0:00 [kworker/3:1H]
  452 ?        Sl     3:16 /usr/local/sbin/pilight-daemon
  498 ?        Ssl    0:00 /usr/sbin/rsyslogd -n
  522 ?        S      0:00 /usr/sbin/dnsmasq -x /var/run/dnsmasq/dnsmasq.pid -u d
  578 ?        Ssl    0:10 /usr/bin/memcached -m 64 -p 11211 -u memcache -l 127.0
  640 ?        S      0:00 sudo java -server -classpath /home/pi/workspace/java/p
  658 ?        Ss     0:15 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -c /var/lib/ntp
  747 ?        S      0:02 /usr/sbin/xrdp
  749 ?        S      0:01 /usr/sbin/xrdp-sesman
  764 ?        Sl     2:27 java -server -classpath /home/pi/workspace/java/px_hom
  796 tty1     Ss+    0:00 /sbin/agetty --noclear tty1 linux
  797 ttyAMA0  Ss+    0:00 /sbin/agetty --keep-baud 115200 38400 9600 ttyAMA0 vt1
  808 ?        Ss     0:13 php-fpm: master process (/etc/php5/fpm/php-fpm.conf)
  810 ?        S      0:00 php-fpm: pool www
  811 ?        S      0:00 php-fpm: pool www
  816 ?        Ss     0:09 /usr/sbin/apache2 -k start
  850 ?        S<     0:00 [kworker/0:1H]
 5038 ?        Ss     0:00 /lib/systemd/systemd --user
 5043 ?        S      0:00 (sd-pam)
 5068 ?        S      0:00 /usr/sbin/xrdp-sessvc 5074 5073
 5073 ?        Sl     0:00 /usr/bin/lxsession -s LXDE-pi -e LXDE
 5074 ?        S      0:37 Xvnc :10 -geometry 1364x768 -depth 16 -rfbauth /home/p
 5077 ?        Sl     0:00 xrdp-chansrv
 5100 ?        Ss     0:00 /usr/bin/ssh-agent /usr/bin/dbus-launch --exit-with-se
 5103 ?        S      0:00 /usr/bin/dbus-launch --exit-with-session x-session-man
 5104 ?        Ss     0:00 /usr/bin/dbus-daemon --fork --print-pid 11 --print-add
 5114 ?        Sl     0:00 /usr/lib/gvfs/gvfsd
 5118 ?        Sl     0:00 /usr/lib/gvfs/gvfsd-fuse /run/user/1000/gvfs -f -o big
 5129 ?        S      0:00 openbox --config-file /home/pi/.config/openbox/lxde-pi
 5132 ?        Sl     0:00 lxpolkit
 5134 ?        Sl     1:54 lxpanel --profile LXDE-pi
 5135 ?        Sl     0:00 pcmanfm --desktop --profile LXDE-pi
 5141 ?        Ss     0:00 /usr/bin/ssh-agent -s
 5148 ?        Ssl    0:00 /usr/lib/policykit-1/polkitd --no-debug
 5159 ?        Sl     0:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
 5163 ?        Ssl    0:00 /usr/lib/udisks2/udisksd --no-debug
 5173 ?        Sl     0:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
 5177 ?        Sl     0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
 5181 ?        Sl     0:00 /usr/lib/gvfs/gvfs-goa-volume-monitor
 5184 ?        Sl     0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
 5196 ?        Sl     0:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.1 /org/gtk/gvfs
 5197 ?        Ssl    0:00 /usr/lib/menu-cache/menu-cached /tmp/.menu-cached-:10-
 6464 ?        S      0:03 [kworker/0:1]
 6514 ?        S      0:04 [kworker/3:2]
 6676 ?        Ss     0:00 /usr/sbin/sshd -D
 7389 ?        Ssl    0:00 /usr/lib/packagekit/packagekitd
 7690 ?        S      0:00 /usr/sbin/xrdp-sessvc 7703 7702
 7693 ?        Ss     0:00 /lib/systemd/systemd --user
 7698 ?        S      0:00 (sd-pam)
 7702 ?        Sl     0:01 /usr/bin/lxsession -s LXDE-pi -e LXDE
 7703 ?        S      0:00 Xvnc :11 -geometry 1364x768 -depth 16 -rfbauth /home/w
 7707 ?        Sl     0:00 xrdp-chansrv
 7730 ?        Ss     0:00 /usr/bin/ssh-agent env TMPDIR=/tmp /usr/bin/dbus-launc
 7733 ?        S      0:00 /usr/bin/dbus-launch --exit-with-session x-session-man
 7734 ?        Ss     0:00 /usr/bin/dbus-daemon --fork --print-pid 11 --print-add
 7755 ?        Sl     0:00 /usr/lib/gvfs/gvfsd
 7759 ?        Sl     0:00 /usr/lib/gvfs/gvfsd-fuse /run/user/1001/gvfs -f -o big
 7769 ?        S      0:00 openbox --config-file /home/wweb/.config/openbox/lxde-
 7771 ?        Sl     0:00 lxpolkit
 7774 ?        Sl     0:00 lxpanel --profile LXDE-pi
 7775 ?        Sl     0:01 pcmanfm --desktop --profile LXDE-pi
 7784 ?        Ss     0:00 /usr/bin/ssh-agent -s
 7788 ?        Sl     0:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
 7796 ?        Sl     0:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
 7801 ?        Sl     0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
 7805 ?        Sl     0:00 /usr/lib/gvfs/gvfs-goa-volume-monitor
 7809 ?        Sl     0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
 7818 ?        Sl     0:01 /usr/lib/gvfs/gvfsd-trash --spawner :1.1 /org/gtk/gvfs
 7974 ?        S      0:09 [kworker/1:2]
 8493 ?        S      0:00 [kworker/1:0]
 9053 ?        S      0:05 /usr/sbin/apache2 -k start
 9054 ?        S      0:04 /usr/sbin/apache2 -k start
 9055 ?        S      0:06 /usr/sbin/apache2 -k start
 9056 ?        S      0:04 /usr/sbin/apache2 -k start
 9057 ?        S      0:03 /usr/sbin/apache2 -k start
10544 ?        S      0:01 /usr/sbin/apache2 -k start
10546 ?        S      0:00 [kworker/u8:2]
10547 ?        S      0:02 /usr/sbin/apache2 -k start
10548 ?        S      0:01 /usr/sbin/apache2 -k start
10550 ?        S      0:01 /usr/sbin/apache2 -k start
10608 ?        S      0:00 [kworker/3:1]
10609 ?        S      0:00 [kworker/0:0]
10613 ?        S      0:00 [kworker/u8:0]
10614 ?        S      0:00 [kworker/2:0]
10616 ?        S      0:00 [kworker/2:2]
10617 ?        S      0:00 [kworker/2:1]
10619 ?        Ss     0:00 sshd: wweb [priv]
10629 ?        S      0:00 sshd: wweb@pts/0
10632 pts/0    Ss     0:00 -bash
10642 pts/0    S      0:00 sudo su
10653 pts/0    S      0:00 su
10662 pts/0    S      0:00 bash
10663 pts/0    R+     0:00 ps ax
free output
 free
             total       used       free     shared    buffers     cached
Mem:        883056     581396     301660      25380     108588     286356
-/+ buffers/cache:     186452     696604
Swap:      1048572          0    1048572
I am quite sure that it's not the ssh connection that poses the problem because when I last tried to use kodi locally on the Pi it showed a behaviour similar to the problems I get when connecting via ssh.
Furthermore I always try to have the latest software on my Pi.
uname -a
 uname -a
Linux raspberrypi 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
MaxK1
Sun May 15, 2016 8:05 am
The only thing I can think of right now is pilight and/or whatever that java server is. /var/log/syslog or /var/log/messages may yield ssome clues as to what is going on. You might want to try stopping pilight and whatever that java thingie is and see if they might be the culprits.
ffel
Sun May 15, 2016 12:34 pm
Ok I killed that java program and stopped pilight to determine if they slow down the system. But I don't think so because I wrote that java program and it does nearly nothing. Furthermore I had both processes running before moving the rootfs and the Pi was running normally.
But to be sure I will leave both of them stopped and look if the performance will improve.
Thank you very much for your efforts so far and I will tell you whether the problem has been solved in a few days when I can access my Pi physically again.
Return to “Advanced users”
