shorty
Feedback for my gentoo disk image (deutsch)
Thu May 12, 2016 2:01 pm
i build a gentoo out of the box solution for rpi2, use the benefits of gentoo .
i dont have options to test this raw disk image working for other users, pls give some feedback if you are interested in ...
what works, what not ... and things you want to have on a newer release
Good for users that don't want waste time by building linux ... including everything you need to get started
you can download it from
https://www.linuxweb.net/dwnld_image.php
it's german! Userlogin same like in raspbian ...
some informations here: http://raspberry.linuxweb.net/?id=rpi2compatibilitylist
you can add packages that are available in portage ... feel free!
Greetings
Shorty
http://raspberry.linuxweb.net/dwnld_image.php (checksum: 4075a1514561cb9e56590b4340aad540
gentoo raw disk image 3 gb) 4.4.18+v7 -> NEVER TAKE SHOTS WITH A XENON FLASH FROM YOUR RPI2 !
shorty
Re: Feedback for my disk image
Fri May 13, 2016 8:26 am
i will buy a rpi3 to see if the image is portable
and make the wlan work
shorty
Thu May 19, 2016 8:47 am
merged software: http://linuxweb.net/dwnld/world (world)
i think there is no 64bit kernel available so far for rpi3, else please contact me ...
or i have to build it by myself??
shorty
Re: Feedback for my disk image (deutsch)
Mon May 30, 2016 5:08 pm
is it working on your rpi?
cjan
Fri Sep 23, 2016 11:53 pm
does it wireless support by default, Rpi2?
shorty
Sun Sep 25, 2016 5:44 am
wlan is in! any module that is available in kernel 4.4.18 should be working but must be loaded, the Vilros WLAN-Adapter is set up by default.
Use /etc/conf.d/modules and add it in right order, try pluggin it in..
lsusb:
Bus 001 Device 005: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
What Wlan Adapter are you using? I can add it in the next release ...
It would be nice if some other user can tell me about what adapters they are using!
i want to have an overview ...
Have a nice day !
cjan
Sun Sep 25, 2016 8:33 am
one problem, too big to download...downloading break during about 1.3g.
shorty
Sun Sep 25, 2016 8:55 am
sorry, server crashed, try http://linuxweb.net:8080/dwnld_image.php instead
perhaps somebody is able here to provide this file elsewhere, i'd like to get the count of the downloaded file in certain intervals
an update is neccessary, it's outdated - but you can do it by yourself too ...
cjan
Sun Sep 25, 2016 11:06 am
ok, will wait next update.
shorty
Re: Feedback for my gentoo disk image (deutsch)
Mon Sep 26, 2016 8:48 am
i' ve problems compiling omxplayer from portage in case of wrong included headers from userland ...
but a new release is online without the movieplayer ;)
cjan
Mon Sep 26, 2016 12:46 pm
ok, need md5sum to make sure is it correct?
can not mount root fs during booting....
shorty
Mon Sep 26, 2016 2:12 pm
ok, do you see any messages
cjan
Mon Sep 26, 2016 5:56 pm
shorty wrote:ok, do you see any messages
where is md5sum ????
shorty
Tue Sep 27, 2016 6:56 am
here it goes:
7dafbeed0d30bf4267587c6974f77bfa gentoo.img.gz
cjan
Tue Sep 27, 2016 7:24 am
md5sum check ok.
but, mmcbl0p3 is 5XG > my 16G card after flashed.
wonder you had test yourself?
shorty
Tue Sep 27, 2016 7:57 am
thank you for telling me, i've tested with a previous release with a big card
did you resize fs?
is it booting?
I'll fix this
cjan
Tue Sep 27, 2016 8:18 am
shorty wrote:thank you for telling me, i've tested with a previous release with a big card
did you resize fs?
is it booting?
I'll fix this
mmcblk0p3 error, can not boot so no resize-card.
and, can not open inbox message you send.
btw, is it possible to setup wireless (no wired) form stage3?
shorty
Tue Sep 27, 2016 1:27 pm
not that i know of, perhaps in other archs
if not that would be a nice feature, inform me when it is possible
iwconfig isn't present, ifconfig is
i think there is missing some things
you have the loopback by default
shorty
Mon Oct 03, 2016 4:50 pm
it still takes time!
shorty
Tue Jan 03, 2017 1:12 pm
i am currently working on a new release, with fixed filesystem and partition:
for those who using the old image this should help:
you should use gparted or parted!
new on next image:
display link, dual monitors, newer kernel.
shorty
Sat Jan 07, 2017 3:21 pm
look & feel:openbox theme, icons and gtk theme
cjan
Sun Jan 08, 2017 7:52 am
shorty wrote:look & feel: openbox, icons and gtk theme
new img download link ?
shorty
Sun Jan 08, 2017 10:05 am
still compiling: coming soon
shorty
Fri Jan 13, 2017 11:02 am
i think about using F2FS instead of ext4
shorty
Mon Jan 23, 2017 8:39 am
Hey,
a new image is online, but i couldn't test it by myself yet because i'm busy with other work and i done this by remote.
it's about ~3 gb. the partition table is fixed but i can't move the main partition to other blocks, so there may be problems @ boot again when using a 8gb card. So 16 gb is recommended to be safe.
When anybody is going to test it and let me know if the image and booting is OK . Then i can go further make it done.
click here to download
gunzip -c gentoo.img.gz | dd of=/dev/sdX
 # X is your disk
there are several issues but not kind of high priority ... i must switch to another clock system (clock skew warnings / swclock or turn time to future, runlevel script as 1st)
openrc-run coming soon ..
Greetings + success
Return to “Gentoo”
