gdt
Rackmount mounting
Thu May 12, 2016 7:21 am
The low power used by the RPi3 makes it attractive for some telecommunications tasks.
We are having trouble finding a mounting or case for one or more RPi3s which would fit in a 19in rack.
In the worst case we'll use a shelf, but a more secure mounting would be very appreciated as then we could run the RPi3s caseless for better cooling.
In an ideal world that system would also include dual AC power supples feeding a common DC bus to which the RPi3s are attached. But we're electronics people and can do that ourselves if needed.
DavidSturzenbecher
Re: Rackmount mounting
Wed May 18, 2016 1:45 am
I just took a 2 RU blank, drilled 4 holes, and then mounted the pi on the back. Pick up a right angle micro USB and you are set.
rln
Wed May 18, 2016 10:37 am
What about the BitScope Blade rack?
http://www.bitscope.com/product/BB04/
P.S. For such a system I would recommend my OS Nard. It's created for industrial embedded. :)
http://www.arbetsmyra.dyndns.org/nard/
Author of the robust Nard distro http://www.nard.se
