Hello everyone
This might be a odd question but what do you guys think i should do.
Buy a raspberry pi 3 for €40 or
Buy a banana pi m3 with double the specs for €80
thanks in advance
I did not ask on banana pi forum because there is nearly no one there. The banana pi m3 has 2gb ram and octacore processer.texy wrote:Double?
I assume you've asked the same questions at the banana pi forum - assuming there is one.
The answers you'll get here may be a little biased![]()
Texy
I plan on mostly using it as a home server. I might also do a little bit of tinkering with GPIOs but not that much. I also want to code on it (nothing heavy).mthomason wrote:Difficult to make a recommendation without knowing what you want to use it for, and how badly you could use the money saved elsewhere.
Personally, I'd probably go with whatever is sufficient to do the job you want it for with enough elbow room for a year or so's expansion. If you're looking for a do-everything home server, or to use as an actual workstation, then it's probably best to go with the biggest thing you can afford. If you're looking for something to turn on for a couple of hours a week to tinker with, buy the cheapest (especially if you're planning on poking with GPIOs - best to have something you're not going to feel too bad about accidently trashing). If you're looking to learn, well, you already saw how active the forums here are vs the alternative, so that pretty much tells you which brand you'll get the best user-to-user support with
I'd probably use the money to buy a pair of Raspberry Pi 3s, that way you have one stable, running as the server, and the other to mess around with GPIOs and coding on. Nothing worse than thinking "I'd love to do X, but... I need to keep the server running because it's running my website / hosting my mail domain / streaming a movie to my sibling right now"Spekham2013 wrote: I plan on mostly using it as a home server. I might also do a little bit of tinkering with GPIOs but not that much. I also want to code on it (nothing heavy).
good point i'll think about itmthomason wrote:I'd probably use the money to buy a pair of Raspberry Pi 3s, that way you have one stable, running as the server, and the other to mess around with GPIOs and coding on. Nothing worse than thinking "I'd love to do X, but... I need to keep the server running because it's running my website / hosting my mail domain / streaming a movie to my sibling right now"Spekham2013 wrote: I plan on mostly using it as a home server. I might also do a little bit of tinkering with GPIOs but not that much. I also want to code on it (nothing heavy).
I think you should buy both. Try to use them. Report your experiences back here....what do you guys think i should do. Buy a raspberry pi 3 for €40 or Buy a banana pi m3 with double the specs for €80
Maybe Allwinner is just a department of the Chinese secret service:-)
Thats what youll lose if you get a bananapi. Support from the communitySpekham2013 wrote:I did not ask on banana pi forum because there is nearly no one there. The banana pi m3 has 2gb ram and octacore processer.texy wrote:Double?
Texy
