This is the list of services, including Google Cloud Print Service, that I have installed and/or configured:
- CUPS
- Samba*
- AirPrint (for the iDevices and Windows 10)
Services not configured:
- Google Cloud Print Service
*having issues with this setup.
The issue I'm facing is making an automatic installation of the printer drivers using the PostScript file (PPD). I had this working in Ubuntu a long time ago, and now, I cannot seem to get this to work in Raspbian Jessie.
Here's my smb.conf file:
[global]
workgroup = WORKGROUP
security = user
printing = cups
printcap name = cups
load printers = yes
[printers]
comment = All Printers
browseable = no
path = /var/spool/samba
printable = yes
guest ok = yes
public = yes
read only = yes
writable = no
printing = CUPS
[print$]
comment = Printer Drivers
path = /usr/share/cups/drivers
browseable = yes
read only = yes
guest ok = no
writable = no
write list = root, @lpadmin, pi
[PSC-750]
printer name = PSC-750
comment = HP PSC 750
printable = yes
public = yes
guest ok = yes
cupsaddsmb -a -v -H localhost -U root
Password for pi required to access localhost via SAMBA: *********
Running command: smbclient //localhost/print$ -N -A /tmp/01f19573c0d06 -c 'mkdir W32X86;put /tmp/01f19573bfc1b W32X86/PDF.ppd;put /usr/share/cups/drivers/ps5ui. dll W32X86/ps5ui.dll;put /usr/share/cups/drivers/pscript.hlp W32X86/pscript.hlp; put /usr/share/cups/drivers/pscript.ntf W32X86/pscript.ntf;put /usr/share/cups/d rivers/pscript5.dll W32X86/pscript5.dll'
Unable to copy Windows 2000 printer driver files (2).
Running command: smbclient //localhost/print$ -N -A /tmp/01f19573c64bb -c 'mkdir W32X86;put /tmp/01f19573bfc1b W32X86/PDF.ppd;put /usr/share/cups/drivers/ps5ui. dll W32X86/ps5ui.dll;put /usr/share/cups/drivers/pscript.hlp W32X86/pscript.hlp; put /usr/share/cups/drivers/pscript.ntf W32X86/pscript.ntf;put /usr/share/cups/d rivers/pscript5.dll W32X86/pscript5.dll'
Running command: smbclient //localhost/print$ -N -A /tmp/01f19573c8b41 -c 'mkdir W32X86;put /tmp/01f19573bfc1b W32X86/PDF.ppd;put /usr/share/cups/drivers/ps5ui. dll W32X86/ps5ui.dll;put /usr/share/cups/drivers/pscript.hlp W32X86/pscript.hlp; put /usr/share/cups/drivers/pscript.ntf W32X86/pscript.ntf;put /usr/share/cups/d rivers/pscript5.dll W32X86/pscript5.dll'
Edit: it was that error. Apparently, it helps if the idiot installed smbclient and ran the cupsaddsmb command again... Problem solved.
