DatOneLefty
How to use 2 GPIO displays on one Pi Zero?
Tue May 10, 2016 1:58 am
I'm working on a a project like the hololens and i need to be able to have 2 displays hook up to the same Raspberry Pi Zero. The displays will both be a 2.2 inch 18-bit color TFT LCD display with MicroSD card breakout from Adafruit (I am also wondering where i can get the driver for this device). If you can help, that would be wonderful! :D
scotty101
Re: How to use 2 GPIO displays on one Pi Zero?
Tue May 10, 2016 9:32 am
Do you mean this screen?
https://www.adafruit.com/product/1480
The one that has an adafruit tutorial for it?
https://learn.adafruit.com/user-space-s ... li9341-2-8
Also mentioned is that there might be linux framebuffer support for it.
http://www.raspihub.com/go/ac29feb920db ... 526a9e3ae0
and someone has used that to write a simple tutorial
http://aaron-brown.net/blog/?p=99
The refresh rate on these SPI screens isn't great and connecting two screens probably won't give you the result you are looking for.
DatOneLefty
Tue May 10, 2016 10:00 pm
any other screens of this size or a little smaller that are better? If so, how could I use two displays of that kind?
tinylcd
Wed May 11, 2016 4:18 am
hello
in case you are planning to have mirror images on two displays than
you can have a look at the below product
http://www.neosecsolutions.com//product ... 9&cPath=20
regards
tinylcd
