Twinkletoes
Multiple GLES contexts
Thu Aug 16, 2012 11:27 pm
Does anyone have any code to create a second GLES context?
I'm looking to run two threads sharing texture and shader resources.
I'm basing my demo on hello_triangle 2.
void CreateSecondaryOpenGLContext()
static const EGLint context_attributes[] =
EGL_CONTEXT_CLIENT_VERSION, 2,
EGL_NONE
EGLContext context = eglCreateContext(GlobalOpenGlState->display,
GlobalOpenGlState->config,
GlobalOpenGlState->context,
context_attributes);
// release surface so that second thread can render
eglMakeCurrent(GlobalOpenGlState->display, EGL_NO_SURFACE, EGL_NO_SURFACE, EGL_NO_CONTEXT);
// connect the context to the surface
int result = eglMakeCurrent(GlobalOpenGlState->display, GlobalOpenGlState->surface, GlobalOpenGlState->surface, context);
assert(EGL_FALSE != result);
check();
The assertion fails. Any thoughts?
jackokring
Contact: ICQ
Re: Multiple GLES contexts
Thu Aug 16, 2012 11:45 pm
Is this to display something like a rear view mirror view? Is it possible to set a Texture2D in the fragment shader? Is it possible to run two different vertex shaders (transformed views) by if/else?
Cheers Jacko
Pi[NFA]=B256R0USB CL4SD8GB Raspbian Stock.
Pi[Work]=A+256 CL4SD8GB Raspbian Stock.
My favourite constant 1.65056745028
jackokring
Contact: ICQ
Fri Aug 17, 2012 2:09 am
Something like the following untested fragment shader outline. The vertex shader also needs to if/else on mainRender.
vec4 otherRender[size];
if(mainRender == 1) {
  mainColor = (mirrorIn) ? mirrorRender[[gl_FragCoord.x*scaleX + gl_FragCoord.y * width*scaleY] : mainCalcColor;
  gl_FragColor = mainColor;
  otherRender[gl_FragCoord.x + gl_FragCoord.y * width] = mainColor;
} else /* mirror render */ {
  gl_FragColor = otherRender[gl_FragCoord.x + gl_FragCoord.y * width];
  mirrorRender[gl_FragCoord.x + gl_FragCoord.y * width] = mirrorColor;
Cheers Jacko
blu
Fri Aug 17, 2012 7:38 am
Hi Twinkletoes. As it is not exactly clear from your post: are you trying to create a second context for a second thread to use _concurrently_ with an original context? If so, then I don't know whether that could work (read: most likely not). What might work, though, (and I haven't done anything multi-context on the Pi, so citing from memory here) should work like this:
You have one context. To make it usable in another thread, you unbind the context from the original creator thread, by eglMakeCurrent(NO_SURFACE, NO_SURFACE, NO_CONTEXT), then you bind the same context in the second thread, where you do your 2nd-thread work. Once finished, you unbind again from the second thread, so you can bind it back again in the first one. Basically, there's no concurrency, as you notice. Such a use-pattern is mainly useful when you have an asset-feeder thread, which might occasionally 'grab' the context, load some assets, then yield it back to the original rendering thread.
Here's also a khronos.org thread you might find useful: http://www.khronos.org/message_boards/v ... f=4&t=1328
Twinkletoes
Fri Aug 17, 2012 8:06 am
Yes I want concurrency. My textures are large (8-16MB), so I want one thread to load them without stalling the render context. Once they're loaded then they'll be used by the second thread, which has carried on rendering with the old textures in the mean time.
Can't see the point of sharing a single context between threads - if one can only use it when the other is blocked, why have multiple threads?
blu
Fri Aug 17, 2012 8:23 am
Twinkletoes wrote:Yes I want concurrency. My textures are large (8-16MB), so I want one thread to load them without stalling the render context. Once they're loaded then they'll be used by the second thread, which has carried on rendering with the old textures in the mean time.
Your use-case is exactly what I meant with the one-context scenario above. Behold:
Render thread:
1. grabs context
2. sets state
3. emits draw calls & flushes
4. yields context
Asset thread:
1. loads/generates/processes raw assets
2. grabs context
3. uploads assets to context
4. yields context
Now, assuming the main workload for Render thread is in steps 2 and 3 (after which the actual GPU work starts), while the main workload for Asset thread is in step 1, voila - you get concurrency with one context.
jackokring
Contact: ICQ
Fri Aug 17, 2012 8:44 am
Render thread:
1. grabs context
1a. check que and pass in object if one queued
2. sets state
4. loop to 1a
Asset thread:
2. nothing to do here
3. que asset for render
4. loop to 2
Is also possible.
Return to “OpenGLES”
