rasperilice15
How to edit config.txt while using hdmi to vga converter?
Sun May 08, 2016 3:52 pm
Hi guys,
I have a raspberry pi 3 and installed the latest version of windows 10 iot core on a micro sd card by following the steps on Micrsoft's web site. I'm using a vga monitor and have an hdmi to vga converter to connect my raspberry pi 3. At first, I couldn't get any image on screen. After a quick web search, I found out that I should edit the config.txt to get any image. I tried a few suggestion on the web, but couldn't achieve it.
Below is what is written in my config.txt. Where and what exactly should I change or add?
gpu_mem=32                  # set ARM to 480Mb DRAM, VC to 32Mb DRAM
framebuffer_ignore_alpha=1  # Ignore the alpha channel for Windows.
framebuffer_swap=1          # Set the frame buffer to be Windows BGR compatible.
disable_overscan=1          # Disable overscan
init_uart_clock=16000000    # Set UART clock to 16Mhz
hdmi_group=2                # Use VESA Display Mode Timing over CEA
arm_freq=900
arm_freq_min=900
force_turbo=1
PS: I found similar topics on this forum, but they couldn't solve my problem, because they are offering changing or uncommenting some lines which are not included in my config file as seen above.
Dis93
Re: How to edit config.txt while using hdmi to vga converter
Sun May 08, 2016 4:06 pm
What resolution is your monitor?
I'm using a 1920x1080 monitor with a HDMI to DVI convertor and had to add
hdmi_mode=82
hdmi_drive=1
to get the correct resolution. The mode number will be different for you if you have a different resolution.
mikerr
Sun May 08, 2016 4:37 pm
I'd start with
hdmi_safe=1
in there. If that works, you can then find individual settings.
Your HDMI VGA convertor may be stopping the pi from detecting HDMI, and so turning it off, try:
hdmi_force_hotplug=1
