Dis93 wrote:Yeah, I'm using the OTG adapter provided with the essentials kit that came with my Zero from PiHut.
Yes, just missed your last post. You might be able to check if the USB is OK if you connect the Pi Zero to a USB port on a PC or laptop with a normal USB cable and see what it shows. I believe it should show as some sort of device if it is working.
EDIT: Just tried with a Pi Zero connected to my Win7 laptop. Don't see anything with an SD card plugged into the Pi Zero, But without the SD card plugged in I see a device "BCM2708 Boot".
MrEngman
