HolyGuacamole
Setting up a wifi network on the pi 3 without the GUI
Sun May 08, 2016 9:21 am
Hello forum,
I am trying to tether the internet from the ethernet port to a new wifi network.
The device is a raspberry pi 3 b, which has an onboard wifi module.
I am accessing the pi using SSH. This means that using the GUI (graphical user interface) is not that easy.
I want to use the CLI (command line interface) version for managing (and tethering) the connections of the pi instead of the GUI.
- what is it called?
- where can I find it?
- how does it work?
Thanks in advance.
B.Goode
Re: Setting up a wifi network on the pi 3 without the GUI
Sun May 08, 2016 9:36 am
The Raspberry Pi Foundation documentation probably precedes the RPi3, but it looks as though it is still applicable:
https://www.raspberrypi.org/documentati ... ess-cli.md
(Disclaimer: reference to documentation only - I don't have an RPi3 to check with.)
HolyGuacamole
Sun May 08, 2016 10:14 am
B.Goode wrote:The Raspberry Pi Foundation documentation probably precedes the RPi3, but it looks as though it is still applicable:
the title of the page is
Setting WiFi up via the command line
but it appears to be about connecting to an existing wifi network.
What I want to do is create a new wifi network using the raspberry pi as the wireless access point.
So I can connect to the wifi network with another device.
MrEngman
Sun May 08, 2016 11:08 am
Take a look here viewtopic.php?p=948118#p948118. This describes how I set up a basic Access Point which works on a variety of different Pi. I have tried a Pi 3B, 2B, B+ and Pi 1 with 512MB ram and it works on all four.
I basically talks about using a TP-Link TL-WN725N wifi adapter but if you go to the end of the post, last paragraph or two, you will see I have also tested it with a Pi 3B using the built in Broadcom wifi.
MrEngman
B.Goode
Sun May 08, 2016 11:16 am
HolyGuacamole wrote: What I want to do is create a new wifi network using the raspberry pi as the wireless access point.
I misunderstood the point of your query, and as a result my reply was irrelevant. My apologies.
HolyGuacamole
Sun May 08, 2016 1:54 pm
B.Goode wrote: I misunderstood the point of your query, and as a result my reply was irrelevant. My apologies.
Thanks anyway! :D
Any attempt at helping is always welcome.
HolyGuacamole
Sun May 08, 2016 2:47 pm
MrEngman wrote:Take a look here viewtopic.php?p=948118#p948118. This describes how I set up a basic Access Point which works on a variety of different Pi. I have tried a Pi 3B, 2B, B+ and Pi 1 with 512MB ram and it works on all four.
MrEngman
I don't understand it.
Why are all those steps necessary?
MrEngman
Sun May 08, 2016 3:07 pm
MrEngman
To get it to work, what else.
However, if you are using the Pi 3 B built in Broadcom wifi then you can ignore loading the driver for the TL-WN725N.
MrEngman
HolyGuacamole
Tue May 10, 2016 8:36 pm
Got anything simpler?
MrEngman
Tue May 10, 2016 9:02 pm
OK, striped out the bits you don't need.
So, first I formatted the SD card with SDFormatter v4.0 on my Windows 7 laptop, using full overwrite and Format Size Adjustment ON. I then copied the image, 2016-03-18-raspbian-jessie-lite, to the SD card using Win32DiskImager 0.9.5.
I inserted the card into the Pi, connected the Pi to my network using an ethernet cable and powered on the Pi. I connected to the Pi from my laptop using SSH and started to set it up. First ran
sudo raspi-config
and expanded the file system, set timezone, hostname and boot to desktop. Then rebooted.
After booting ran
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install rpi-update
sudo rpi-update
and rebooted.
You should now be able to check the wifi is working with command
sudo iwlist wlan0 scan
This should show a list of wifi networks, provided of course there are any near you.
Now to configure the AP, first installing the necessary packages and files required.
sudo apt-get update
sudo apt-get install bridge-utils hostapd
and now update hostapd to handle the realtek wifi
wget https://dl.dropboxusercontent.com/u/80256631/hostapd
sudo mv hostapd /usr/sbin/hostapd
sudo chown root.root /usr/sbin/hostapd
sudo chmod 755 /usr/sbin/hostapd
Now set up the /etc/network/interfaces file like
auto lo
iface lo inet loopback
iface eth0 inet dhcp
auto br0
iface br0 inet dhcp
bridge_ports eth0 wlan0
and the /etc/hostapd/hostapd.conf file like
interface=wlan0
driver=nl80211
bridge=br0
ssid=Network-Name
channel=1
wmm_enabled=0
wpa=1
wpa_passphrase=Network-Password
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
macaddr_acl=0
substituting the network name and password you want to use.
The set up should now be ready to test so first reboot your Pi.
After logging in run command
sudo hostapd -dd /etc/hostapd/hostapd.conf
to start the AP. I tested my AP by connecting my Windows laptop to the AP.
Once you determine the AP is working edit file /etc/default/hostapd to get the AP to automatically start when the Pi boots. In file /etc/default/hostapd uncomment line
#DAEMON_CONF=""
and change it to
DAEMON_CONF="/etc/hostapd/hostapd.conf"
After rebooting the AP should automatically start.
MrEngman
Return to “Beginners”
