Rive
Configure, disable screensaver, blankscreen, and lockscreen
Sat May 07, 2016 1:49 pm
LXDE in Debian/Raspbian has its own ability to setup lockscreen, turn off the monitor, and put it into a true "power save" mode (not screen blanking), etc. You just have to enable it is all (or simply disable it all if that is your preference).
Click here to setup lockscreen, put monitor into a true powersave mode, and configure settings
Here is how to turn it all OFF:
DISABLE IT ALL. NO SCREEN BLANKING, NO POWERSAVE MODE, NO SCREENLOCK. MONITOR STAYS ON ALL THE TIME
open:
sudo nano ~/.config/lxsession/LXDE-pi/autostart
add:
@xset s 0 0
@xset s noblank
@xset s noexpose
@xset dpms 0 0 0
'select all', then right click 'copy', then scroll to bottom with down arrow key, then 'paste'
so it looks like this:
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@xscreensaver -no-splash
@xset s 0 0
@xset s noblank
@xset s noexpose
@xset dpms 0 0 0
save with 'Ctrl' + 'x' key, then 'y', then 'enter'
then:
sudo reboot
You will reboot and you are done. ;) No screensaver, no screen blanking, no monitor power saving mode.
DNPNWO
Rive
Re: Configure, disable screensaver, blankscreen, and lockscr
Sat May 07, 2016 2:12 pm
Configure the built in lxde screensaver, lock screen, and monitor (actually turn offs, not screen blanking) power save features via lightlocker which uses the Jessie login screen. This also allows you to use the keyboard shortcut to screenlock:
Instructional youtube video:
https://youtu.be/aTrp83lgq_s
xset q
note- "xset q" is useful for checking screen and dpms settings, and changing them for testing (e.g., Monitor "off" is set for 1200 sec, or 20 min, and you want to test it, so you set dpms to 10 sec (xset dpms 0 0 10)). Changes here are temporary, and will not survive a reboot.
Run:
sudo apt-get install light-locker
Open:
sudo nano /boot/config.txt
Add:
# uncomment to put the monitor into power saving mode (DPMS)
hdmi_blanking=1
Open:
Add:
@xset s 0 0
@xset s noblank
@xset s noexpose
@xset dpms 0 0 1200
Save with 'Ctrl + x', then 'y', then 'enter'
open:
(note- if you do an "apt-get dist-upgrade" instead of an "apt-get upgrade", you will need to re-add this keybind)
nano ~/.config/openbox/lxde-pi-rc.xml
find:
 <!--keybindings for LXPanel →
add:
      <keybind key="C-A-L">
    <action name="Execute"><command>lxlock</command></action>
  </keybind>
The above dpms '1200', means turn off monitor after 20min, and lock screen with light-locker (lxlock). Change to whatever time you want (in seconds).
If you do not want screen to autolock
If you prefer screen to just turn off/go into power save mode, and resume if you move mouse, or hit a key WITHOUT requiring login, and wish to manually do screenlock, then;
open
sudo nano /etc/xdg/autostart/light-locker.desktop
find "Exec=light-locker", change to
Exec=light-locker --lock-after-screensaver=0 --no-lock-on-suspend --no-late-locking
sudo reboot
Shortcuts:
1. add "ScreenLock" Menu shortcut (via Menu/Preferences/Main Menu Editor/Other/)
2. use keyboard 'Ctrl ' + 'Alt' + 'L' to turn off monitor and lock screen
DNPNWO
Reini1000
Thu Jun 09, 2016 6:22 am
Hi, i followed this Discription:
open:
add:
@xset s 0 0
@xset s noblank
@xset s noexpose
@xset dpms 0 0 0
@xset s 0 0
@xset s noblank
@xset s noexpose
@xset dpms 0 0 0
then:
sudo reboot
But my screen still goes idle after a certain time of inactivity.
I have to mention that i'm using the 7" Raspberry Pi Touchscreen and i'm not booting to the desktop, but to the text console. I'm using a script which automaticly boots into Kweb Browser if you choose the Console Autologin in the raspi-config.
so how can i force the Display to stay on all the time ?
Thanks for helping me in advance.
dasmanul
Thu Jun 09, 2016 8:06 am
Can't tell you why it's not working, but these work for me:
@xset -dpms
@xset s noblank
@xset s off
Maybe worth a try?
Reini1000
Fri Jun 10, 2016 6:53 am
Thanks, but that wasn't succesful either.
What should i do, I have no idea how to force the Display to stay on ?
dasmanul
Fri Jun 10, 2016 9:23 am
Have you tried entering these 3 commands manually (without the @'s)? Maybe that can give you some clue on what goes wrong.
What does "xdg-screensaver status" give you before and after that?
Reini1000
Fri Jun 10, 2016 9:35 am
hi no matter if I add @ or not, always the same message
pi@raspberrypi:~ $ xdg-screensaver status
xset: unable to open display ""
/usr/bin/xdg-screensaver: 829: [: Illegal number:
/usr/bin/xdg-screensaver: 831: [: Illegal number:
ERROR: xset q did not report the screensaver timeout
dasmanul
Fri Jun 10, 2016 10:22 am
This looks like you're logged in remotely to your Pi. Try issuing
export DISPLAY=:0
first and then repeat the commands.
Reini1000
Fri Jun 10, 2016 10:33 am
Yes i'm logged in via SSH.
i have done:
pi@raspberrypi:~ $ export DISPLAY=:0
enabled
dasmanul
Fri Jun 10, 2016 10:44 am
Okay, this clearly shows the screensaver is still active. What happens if, directly afterwards, you type
xset -dpms
xset s noblank
xset s off
Does the screen still go blank/screensaver still come on after that?
Reini1000
Fri Jun 10, 2016 10:49 am
pi@raspberrypi:~ $ xset -dpms
pi@raspberrypi:~ $ xset s noblank
pi@raspberrypi:~ $ xset s off
disabled
Its seems now that the Display stays on. I would be so glad if this was the Trick. Thank you very much !!!
dasmanul
Fri Jun 10, 2016 11:57 am
Glad I could help. What remains, of course, is to find out why the same commands do not work automatically. I'm afraid I can't be of much help there since I don't interactively login to the GUI on any of my PIs. Still, you could post the complete content of your ~/.config/lxsession/LXDE-pi/autostart - maybe someone will spot what's wrong there so you don't have to type these commands every time you log in.
Reini1000
Fri Jun 10, 2016 12:45 pm
Yeah you are right. Because now if restart I have to typ in again the same command
disabled
do Disable the screensaver
my /etc/xdg/lxsession/LXDE-pi/autostart file is containing
@xset -dpms
@xset s noblank
@xset s off
dasmanul
Fri Jun 10, 2016 12:57 pm
Reini1000 wrote: my /etc/xdg/lxsession/LXDE-pi/autostart file is containing
And your ~/.config/lxsession/LXDE-pi/autostart? I believe this overrides the system-wide default file you posted.
If that's identical, I would also try to remove the "xscreensaver" line.
Reini1000
Fri Jun 10, 2016 1:18 pm
My ~/.config/lxsession/LXDE-pi/autostart file contains
@xset -dpms
@xset s noblank
@xset s off
dasmanul
Fri Jun 10, 2016 1:32 pm
So have you tried removing the line containing xscreensaver from that file? Of course, you'll have to log out and in again.
Speakng of which: We're talking about disabling the screensaver when you log in at the Pi itself, are we? If not, how exactly do you log in?
Reini1000
Fri Jun 10, 2016 1:57 pm
dasmanul wrote:So have you tried removing the line containing xscreensaver from that file? Of course, you'll have to log out and in again.
i have tried to remove the xscreensaver line with a #. But nothing changes the screensaver is still on.
Yes i want to disable the screensaver for the pi user.
My setup is: booting with auto-login as pi user to the text console and then autostart the kweb browser.
dasmanul
Fri Jun 10, 2016 2:07 pm
So how do you autostart the kweb browser?
Reini1000
Fri Jun 10, 2016 2:17 pm
dasmanul wrote:So how do you autostart the kweb browser?
I use a script which is called "Kiosk" ( located in /home/pi/kiosk) containing
#!/bin/sh
matchbox-window-manager &
kweb3 –KAJ  http://127.0.0.1:8080/webvisu.htm
and then i edit the .bashrc file
and add at the end of the file:
    if [ $(tty) == /dev/tty1 ]; then
    xinit ./kiosk
    fi
This auto start's the kweb browser if I'm booting in the text console.
dasmanul
Fri Jun 10, 2016 2:35 pm
Well in that case you're not using LXDE at all, so no wonder putting the commands in its startup scripts doesn't work. Try putting the three "xset" commands in your kiosk script - either before or after the "matchbox-window-manager" line, shouldn't matter.
Reini1000
Fri Jun 10, 2016 2:57 pm
Nope
i edit my kiosk file to:
#!/bin/sh
kweb3 -KAJ http://127.0.0.1:8080/webvisu.htm
@xset -dpms
@xset s noblank
@xset s off
but the screens went black again .
do i need the @ ?
dasmanul
Fri Jun 10, 2016 3:00 pm
I don't think you need the @'s but I would put the xset's before the kweb line. Try adding the three commands (without the @'s) directly after the first line.
Reini1000
Fri Jun 10, 2016 3:11 pm
now i have change the Kiosk File to this:
#!/bin/sh
xset -dpms
xset s noblank
xset s off
and i get :
pi@raspberrypi:export DISPLAY=:0
disabled
seems that it worked now. I will wait whether the display stays on or not.
Reini1000
Fri Jun 10, 2016 3:31 pm
Finally this has done the Trick, the Display is on all the time after I change the
Kiosk to:
#!/bin/sh
xset -dpms
xset s noblank
xset s off
Thank you so much !
dasmanul
Fri Jun 10, 2016 3:36 pm
Gern geschehen. :)
