DmitryR
Edit wpa_supplicant.conf from windows computer
Thu May 05, 2016 4:21 pm
Is there a way to add a pair of lines to /etc/wpa_supplicant/wpa_supplicant.conf from a laptop with Windows OS?
The reason is I don't have any HDMI monitor or USB keyboard/mouse, but I want to setup Wi-Fi connection (I have Wi-Fi module and it works, I need to specify Wi-Fi ssid and password).
B.Goode
Re: Edit wpa_supplicant.conf from windows computer
Thu May 05, 2016 5:04 pm
This might help. It reaches the same conclusion in a different way.
viewtopic.php?f=66&t=139190&p=947862&hi ... nt#p947038
(Editting files in the root filesystem of your SD card from a Windows machine is not possible without the installation and use of third-party software that can read/write 'linux' partitions: Windows itself does not have this ability.)
DmitryR
Thu May 05, 2016 5:10 pm
Thank you, so I need to create /boot/wpa-supplicant.conf file.
Could you give me default wpa-supplicant.conf file from Raspberry Pi debian distribution?
DirkS
Fri May 06, 2016 12:54 am
country=GB
update_config=1
network={
        ssid="yourAP"
        psk="yourpasskey"
This should work for WPA(2) and SSID not hidden.
Change country, ssid and psk to the actual values.
IgorGanapolsky
Tue Sep 13, 2016 10:07 pm
DirkS wrote:
country=GB
update_config=1
network={
        ssid="yourAP"
        psk="yourpasskey"
What if I am in USA, would this screw up with country=GB?
davidcoton
Tue Sep 13, 2016 10:24 pm
IgorGanapolsky wrote:What if I am in USA, would this screw up with country=GB?
Yes.
DirkS wrote:Change country, ssid and psk to the actual values.
Signature retired
Return to “Advanced users”
