mikerr
Raspi Imager - Android app to download and install SD cards
Wed May 04, 2016 9:56 am
New android app to download & image raspberrypi SD cards
Prepare bootable SD cards for your Raspberry Pi direct on your phone
- No PC required !
- downloads and installs OS
- images to SD card or USB (card reader)
Can install NOOBS and NOOBS Lite
Supports SD card in phone (if rooted - android limitations), or via USB card reader.
Image Image
https://play.google.com/store/apps/deta ... r&hl=en_GB
topguy
Re: Raspi Imager - Android app to download and install SD ca
Wed May 04, 2016 10:15 am
Nice Mike!
I'm a little unsure by the description if you are only able to install NOOBS or if you also support disk-images like raspbian-lite etc.
I'm guessing Android has some strict limitations to what you can do with SD cards.
mikerr
Wed May 04, 2016 10:42 am
Only NOOBs on the current release for now.
I have an unreleased version that can use .img disk images, but there's potential problems with it
( zip + img needs 5GB storage, and .img wipe cards more than file based noobs)
procount
Wed May 04, 2016 11:20 am
I guess it should be able to install PINN-lite as well from https://sourceforge.net/projects/pinn/f ... p/download?
PINN - NOOBS with the extras... https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=142574
mikerr
Wed May 04, 2016 11:34 am
procount wrote:I guess it should be able to install PINN-lite as well from https://sourceforge.net/projects/pinn/f ... p/download?
Yes, I'll add that one in right now as it's a similar install.
PINN is an enhanced/modifed NOOBs for anyone looking: viewtopic.php?f=63&t=142574
procount
Wed May 04, 2016 12:54 pm
Cheers!
Tip: Beware of the sourceforge mirror redirects.
mikerr
Wed May 04, 2016 2:29 pm
Also added berryboot, update should appear on google play shortly
blaablaaguy
Wed May 04, 2016 3:06 pm
mikerr wrote:Also added berryboot, update should appear on google play shortly
Awesome! Ive always wanted to do stuff like this from my phone. :)
This signature intentionally left blank.
procount
Thu May 05, 2016 11:07 am
I downloaded the first version fine as soon as it came out.
I've uninstalled and upgraded this several times, but I don't get the updated version. The Play store app still shows the old one.
I can see the new version on the google play website, but even installing it from there still doesn't give me the new version.
Does it normally take this long for a new version to become available on the play store?
Or am I suffering from a caching problem somewhere?
procount
Thu May 05, 2016 9:45 pm
Finally it updated. :)
Are you sure Pinn and Berryboot are about 30GB? Perhaps they should be MB... Otherwise it looks great. Must try it out fully.
mikerr
Fri May 06, 2016 10:54 am
Haha, oops yes they're 32MB not GB (updated now)
Techno_IMRAN
Sun Jun 26, 2016 7:38 am
mikerr wrote:New android app to download & image raspberrypi SD cards
- No PC required !
Image Image
Sir,
I downld the app in my android phone but there is none of the STORAGE devices (8GB Pendrive & 16 GB sandisk microsd card on OTG ) showed by the app. I install twice the app but failed. Is this app only for rooted phones?
mikerr
Sun Jun 26, 2016 7:57 am
It only requires rooting if you want to write to the internal sd card.
A usb pendrive or card reader on otg should be fine.
They should be formatted in fat32.
What's the exact model of phone?
Do you know the android path for your pendrive?
Techno_IMRAN
Sun Jun 26, 2016 8:07 am
My phone model is XIAOMI REDMI 1S. All the pen drives, microsd cards, mouse & keyboard detected by the phone OTG perfectly . What should i do right now?? plz suggest any other android app.
bensimmo
Sun Jun 26, 2016 8:36 am
Does it write as it downloads (preferred) or do you download and then write?
Either way i'll check it out, I have various devices with various restrictions on external/internal SD cards to test with.
Techno_IMRAN
Sun Jun 26, 2016 9:05 am
what is the right way ? NOOBS is a huge data eater so i didn't downlad after no USB devices detected by the app. Plz try it on your devices and solve my problem.
mikerr
Sun Jun 26, 2016 3:41 pm
bensimmo wrote:Does it write as it downloads (preferred) or do you download and then write?
Currently download, then write.
As for data sizes, NOOBS lite is only 27 MB
