sunone
MRI data (or other medical images) visualization on raspbian
Thu Aug 16, 2012 12:35 pm
Hi all
I decided that I won't stop until I managed to have a visualization of medical data.
I am starting with something very light (opefully). Called MRIcron
http://www.nitrc.org/frs/?group_id=152
Unfortunately the precompiled binary that works for all the modern distribution is not working:
I receive the error command not executable.
I guess the reason is that it is precompiled with something specific for GTK that is not supported by rapsberry. I am starting digging the source code, I ll post updates. In the meanwhile do you know any work around for precompiled binary based on GTK ?
Cheers
elatllat
Re: MRI data (or other medical images) visualization on rasp
Fri Aug 17, 2012 3:59 am
there is no binary for the arm chip on that site.
you will need to compile it for arm.
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
jackokring
Contact: ICQ
Fri Aug 17, 2012 4:07 am
You may have to translate some of the GL into the subset of it, GLES, but the full GTK+ should compile.
Pi[NFA]=B256R0USB CL4SD8GB Raspbian Stock.
Pi[Work]=A+256 CL4SD8GB Raspbian Stock.
My favourite constant 1.65056745028
Return to “Debian”
