gazbrooks
Light Painting with Rasberry Pi
Thu Aug 16, 2012 12:05 pm
HI all,
I've just bought my first Rasberry Pi, purely for the purposes of Light Painting.
I've since found this link to build a rig for a programmable LED strip. http://learn.adafruit.com/light-paintin ... i/overview
Now i'm stuck with the power side of things! I now it needs a 5 Volt DC power supply but ideally it shows to use a 10amp power supply (as i'll be using a longer LED strip). So how on earth do I go about powering it? I'm new to this and I don't want to risk damaging the circuit board. Ideally I'd need this to be as portable as possible so I can use it outdoors with little to carry.
You can see the type of photographs I currently do here: http://www.flickr.com/photos/garethbrooks
Hope someone can help me!
Thanks everyone,
Gaz
elatllat
Re: Light Painting with Rasberry Pi
Fri Aug 17, 2012 4:06 am
Something like a small UPS battery would be ideal.
Buy one, or get a used one for free;
people throw old ones out all the time.
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
tdk1007
Tue Oct 09, 2012 6:22 am
Hi gazbrooks,
Have you had any success with you light painting rig? I just finished wiring mine up, but am having issues with the code. I know nothing about programming and am really struggling with this.
I have not really found a good way to control the device out in the field. I can only think of bringing a laptop along, ssh into the raspberry pi, and then edit the line of code that points to the hello.png file each time I want to change photos.
As for power, I bought a 6V 5aH battery like this one
http://www.amazon.com/Powerstar-RBC1-Ba ... ah+battery
and a step down converter
http://www.ebay.com/itm/DC-7V-24V-5V-3A ... 3163053%26
Let me know if you make any progress!
