Leonarduino98
Led keeps on blinking
Tue May 03, 2016 10:03 pm
I tried a very simple project connecting a button to the gpio 22 and a led to the gpio 18 to my RPi 2.
My code is this below:
import RPi.GPIO as gpio
gpio.setwarnings(False)
gpio.setmode(gpio.BCM)
gpio.setup(18, gpio.OUT)
gpio.setup(22, gpio.IN)
while True:
    if gpio.input(22) == 0:
        gpio.output(18, gpio.LOW)
        print('low')
    else:
        gpio.output(18, gpio.HIGH)
        print('high')
If i press the button, the led will turn on and the value 'high' appears to the terminal.
The problem is when I release the button: the light doesn't turn off but only decreases the brightness and the values oscillate between 'low' and 'high' continuously.
Did I write something wrong?
Re: Led keeps on blinking
Wed May 04, 2016 5:05 am
You don't have a pull-down resistor in your circuit, so when the button isn't pressed the pin level will "float" and will pick up any random EM radiation in the air which will cause it to flicker between high and low randomly.
You can either add an external resistor, or change your code to use the internal one.
gpio.setup(22, gpio.IN, pull_up_down=gpio.PUD_DOWN)
