jojopi
Re: Permissions to logout/reboot (non pi user)
Tue May 17, 2016 3:35 pm
HawaiianPi wrote:Except the malicious script or application would not be able to run without you knowing it (you would have to enter your password at least once)
As a crude example, imagine you add to my shell configuration:
sudo () { command sudo "[email protected]" && command sudo haxor; }
Unless by some miracle I notice this before the next time I use sudo, you will get root. It does not matter if I have sudo configured to ask for a password, because I will be expecting a password prompt here, and my command will appear to run fine. (You can make the attack work even if I have sudo configured to ask for a password every single time.)
If my sudo/pkexec configurations restrict me to very specific commands such as "reboot" then you may have to find your privilege escalation elsewhere. But if I am a general sysadmin on the box (by any method including su with root password) a compromise of my user account is basically fatal. The only safe thing to do then is reinstall.
Peter Ryan
Tue May 17, 2016 5:01 pm
I've been tied up for a few days so I'm a bit late, but a big thank you to everyone on this thread! :D
Return to “Raspbian”
