Conjur
How do I read the current core clock speed from the SOC
Mon May 02, 2016 7:16 pm
I need the ability to read the current core frequency from C. I do not want a bloated library, nor to execute a script and scrape the output (vcgencmd), nor to read the startup value from config.txt
I have looked through the registers, and can not find anything.
I need to calculate spi dividers dynamically.
V/r,
Mike
Rive
Re: How do I read the current core clock speed from the SOC
Mon May 02, 2016 7:24 pm
Core (GPU) or Arm (CPU)?
Arm:
watch '(vcgencmd measure_clock arm)'
Core:
watch '(vcgencmd measure_clock core)'
DNPNWO
ghans
Tue May 03, 2016 7:53 am
Is think the only stable , userspace interface you get is the virtual "cpufreq" files
in sysfs. Anything else is propably just built on top of that.
Also
cat /proc/cpuinfo | grep "Mhz"
ghans
