Valinath
Splash screen miniature at upper corner
Mon May 02, 2016 6:56 pm
Good evening fellas!
I've been lurking the forums for a long time and now i got a small issue so it is time to get registered ;)
I have an interesting problem and i have not seen anyone else on the web with the same issue.
Both hardware and software is running just fine, but after booting the rainbow splash screen goes into a small icon and positions itself at the displays upper right corner.
I went into /boot/config.txt and put in "disable_splash=1" and rebooted, still the same issue.
Since i don't use the display for anything more than the commandline at this moment, it is not a very big issue but i don't wanna burn the LCD as it sticks ontop of the black screensaver.
And I'm very interested to figure out what's behind this issue!
Pictures can be posted if needed.
Setup:
Rpi3
PiDisplay 7" connected at DSI, power from GPIO#2 (5V) and ground at GPIO#6
I finished an installation at work with the exact same setup, exept i made that one with a raw raspbian image, this one is with noobs, as I've never tried it before. (Same raspbian version (latest jessie))
Thanks for taking the time reading this, I hope you all have a great evening!
Regards,
Val
Ping a Pi? Traceroute the Raspberries!
eastrader
Re: Splash screen miniature at upper corner
Tue May 03, 2016 7:27 pm
I see the same thing on my system. It boots, and runs fine, no extra heat. I have a usb power line monitor, and it never goes below 5.1vdc and never more than .27amps.. so I don't know. I have tried several 5volt power units and I get the same thing on each one. maybe the low volt sense is off. Wish there were a way to calibrate it.
Tue May 03, 2016 9:14 pm
That small rainbow square in the upper right of the display means your power supply is not providing a high enough voltage to run your RPi with its current load. It's below 4.75V. You need a power supply that can provide a steady 5.0V with enough amps to power your RPi and all of your USB peripherals, for a 2B that's 2 amps, for a 3B that's 2.5 amps.
drgeoff
Tue May 03, 2016 10:05 pm
Valinath wrote:I've been lurking the forums for a long time and now i got a small issue so it is time to get registered ;)
The only explanation for the first two sentences I have quoted is that Valinath lurks with his eyes closed! There have been numerous posts about that warning square and the reason. Low voltage from inadequate PSU and/or a cable that is too long or too thin or uses wet string instrad of real copper. There is even a complete section about that square in the sticky viewtopic.php?f=28&t=58151
As it is not a splash, that line in config.txt does not control it.
drgeoff
Tue May 03, 2016 10:08 pm
eastrader wrote:I see the same thing on my system. It boots, and runs fine, no extra heat. I have a usb power line monitor, and it never goes below 5.1vdc and never more than .27amps.. so I don't know. I have tried several 5volt power units and I get the same thing on each one. maybe the low volt sense is off. Wish there were a way to calibrate it.
If you are monitoring at the PSU end of the cable you don't know what voltage the RPi is getting at the other end.
rpdom
Wed May 04, 2016 4:58 am
drgeoff wrote:If you are monitoring at the PSU end of the cable you don't know what voltage the RPi is getting at the other end.
+1
A good place to measure is the 5V GPIO pins 2 or 4, and 0V pin 6 (or any other ground point on the board).
eastrader
Wed May 04, 2016 8:06 pm
Yes, I have 5.0 volts measured with a calibrated digital VOM. Using pins 2 &6. The inline measures 5.01 90% of the time as the lowest point.
Dis93
Wed May 04, 2016 8:11 pm
+1 to rpdom, drgeoff, and DougieLawson for helpful posts.
Dis93
Wed May 04, 2016 8:13 pm
(I also realise my double digit post count pales compared to the stalwarts with quadruple, and quintuple digit post counts ) :D
Valinath
Mon May 09, 2016 11:48 am
My bad, I've must have missed those posts.
Since it looks like a small splash, it is very hard to figure out that it is an actual warning for low voltage.
I thank you kindly for all contributions in this thread, very helpful!
Time to go and grab some PSU's then ;)
Regards,
Val
