I would not personally recommend this overclock, and it leaves only around 415 MB or so of SDRAM for the ARM/CPU... (gpu_mem=320)sprengerle wrote:Hey guys, here s how to overclock your pi safely and mak it very fast:
RaspberryPi 3:
gpu_mem_1024=320
arm_freq=1380
core_freq=500
sdram_freq=500
over_voltage=6
How about this? Is it crazy or what?:Rive wrote:I would not personally recommend this overclock, and it leaves only around 415 MB or so of SDRAM for the ARM/CPU...sprengerle wrote:Hey guys, here s how to overclock your pi safely and mak it very fast:
RaspberryPi 3:
gpu_mem_1024=320
arm_freq=1380
core_freq=500
sdram_freq=500
over_voltage=6
Have you actually tested this crazy overclock to see if it is even stable? Are you even cooling it?
60C is up there, and I hope that is your "stress" temps. I can stress and run cpuburn at 50C all day, and idle at 26C. Normal temps for me, (like browsing with chromium at 17% CPU usage), are at 30C.sprengerle wrote:I am cooling it and the temperature is around 60 degrees and the clock is the highest withe stable working OS![]()
wget https://raw.githubusercontent.com/ssvb/cpuburn-arm/master/cpuburn-a53.S
gcc -o cpuburn-a53 cpuburn-a53.SCode: Select all
while true; do vcgencmd measure_clock arm; vcgencmd measure_temp; sleep 2; done& ./cpuburn-a53Code: Select all
sudo apt-get install libmpich-dev
wget http://web.eece.maine.edu/~vweaver/junk/pi3_hpl.tar.gz
tar -xvzf pi3_hpl.tar.gz
chmod +x xhplCode: Select all
./xhplCode: Select all
./xhplsprengerle wrote:frequency(45)=1380000000
temp=54.5'C
it works fine!
pi@raspberrypi:~ $ while true; do vcgencmd measure_clock arm; vcgencmd measure_temp; sleep 10; done& ./cpuburn-a53
[1] 1244
frequency(45)=1260132000
temp=27.9'C
frequency(45)=1260002000
temp=41.9'C
frequency(45)=1260000000
temp=42.9'C
temp=45.1'C
temp=46.2'C
temp=46.2'C
temp=46.2'C
temp=46.7'C
temp=46.2'C
temp=47.2'C
temp=48.3'C
temp=48.3'C
temp=47.2'C
temp=48.3'C
temp=47.2'C
temp=47.8'C
temp=47.2'C
temp=47.2'C
temp=47.2'C
temp=47.2'C
temp=47.2'C
temp=47.2'C
temp=47.2'C
frequency(45)=1259998000
temp=47.2'C
temp=47.2'C
temp=48.3'C
temp=48.3'C
temp=48.9'C
temp=49.4'C
temp=48.3'C
temp=47.8'C
temp=47.8'C
temp=48.3'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=48.3'C
temp=47.8'C
temp=48.3'C
temp=48.3'C
temp=48.3'C
temp=47.8'C
temp=47.8'C
temp=48.3'C
temp=48.3'C
temp=47.8'C
temp=47.2'C
temp=48.3'C
temp=48.3'C
temp=48.9'C
temp=48.3'C
temp=48.3'C
temp=47.8'C
temp=47.2'C
temp=48.3'C
temp=47.8'C
temp=47.2'C
temp=48.3'C
temp=48.9'C
temp=48.3'C
temp=48.3'C
temp=47.8'C
temp=48.3'C
temp=47.2'C
temp=47.8'C
temp=47.8'C
temp=48.3'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.9'C
temp=49.9'C
temp=49.4'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=47.8'C
temp=48.3'C
temp=48.9'C
temp=48.3'C
temp=48.3'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=48.9'C
temp=47.8'C
temp=48.9'C
temp=47.2'C
temp=48.3'C
temp=47.8'C
temp=48.3'C
temp=48.3'C
temp=47.2'C
temp=48.3'C
temp=49.4'C
temp=48.3'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=48.9'C
temp=48.3'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=48.3'C
temp=48.9'C
temp=48.3'C
temp=47.8'C
temp=47.8'C
temp=47.8'C
temp=47.8'C
temp=47.2'C
temp=48.3'C
temp=49.4'C
temp=48.3'C
temp=48.3'C
temp=48.3'C
temp=48.9'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.9'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=49.4'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=49.4'C
temp=50.5'C
temp=49.9'C
temp=48.3'C
temp=49.4'C
temp=49.4'C
temp=48.3'C
temp=48.3'C
temp=48.3'C
temp=47.8'C
temp=47.8'C
temp=48.3'C
temp=48.3'C
temp=47.2'C
temp=48.3'C
temp=47.8'C
temp=47.2'C
temp=48.3'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.9'C
temp=50.5'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=49.9'C
temp=49.9'C
temp=49.4'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=48.9'C
temp=49.4'C
temp=48.3'C
temp=48.3'C
temp=48.3'C
temp=48.3'C
temp=48.3'C
temp=47.8'C
temp=47.8'C
temp=47.8'C
temp=48.3'C
temp=47.8'C
temp=47.8'C
temp=47.2'C
temp=47.8'C
temp=47.8'C
temp=47.8'C
temp=47.8'C
temp=47.2'C
temp=47.8'C
temp=47.8'C
temp=48.3'C
temp=48.9'C
temp=48.3'C
temp=49.4'C
temp=48.3'C
temp=48.3'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.9'C
temp=48.3'C
temp=49.4'C
temp=49.4'C
temp=48.9'C
temp=48.9'C
temp=49.4'C
temp=48.3'C
temp=48.3'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=48.3'C
temp=48.3'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.9'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=49.4'C
temp=50.5'C
temp=49.4'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.9'C
temp=49.9'C
top - 14:30:28 up 1:02, 1 user, load average: 4.24, 4.29, 4.55
Tasks: 144 total, 5 running, 139 sleeping, 0 stopped, 0 zombie
%Cpu0 :100.0 us, 0.0 sy, 0.0 ni, 0.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu1 :100.0 us, 0.0 sy, 0.0 ni, 0.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu2 :100.0 us, 0.0 sy, 0.0 ni, 0.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu3 : 99.7 us, 0.3 sy, 0.0 ni, 0.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem: 753132 total, 726316 used, 26816 free, 34308 buffers
KiB Swap: 102396 total, 16 used, 102380 free. 471188 cached Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1245 pi 20 0 1680 344 288 R 100.0 0.0 45:38.14 cpuburn-a53
1248 pi 20 0 1680 84 16 R 100.0 0.0 45:38.37 cpuburn-a53
1249 pi 20 0 1680 88 16 R 99.7 0.0 45:31.79 cpuburn-a53
1247 pi 20 0 1680 84 16 R 98.3 0.0 45:36.51 cpuburn-a53
656 root 20 0 120416 43644 19604 S 0.7 5.8 1:33.24 Xorg
1232 pi 20 0 47120 19148 16304 S 0.7 2.5 0:10.32 lxterminal
1679 pi 20 0 5112 2456 2088 R 0.7 0.3 0:08.64 top
1 root 20 0 23904 4040 2788 S 0.0 0.5 0:06.70 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:00.16 ksoftirqd/0
5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:+
7 root 20 0 0 0 0 S 0.0 0.0 0:01.19 rcu_sched
8 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_bh
9 root rt 0 0 0 0 S 0.0 0.0 0:00.01 migration/0
Jessiesprengerle wrote:with OS r u using?
I bet Raspbian
pi@raspberrypi:~ $ ./xhpl
HPLinpack 2.1 -- High-Performance Linpack benchmark -- October 26, 2012
Written by A. Petitet and R. Clint Whaley, Innovative Computing Laboratory, UTK
Modified by Piotr Luszczek, Innovative Computing Laboratory, UTK
Modified by Julien Langou, University of Colorado Denver
An explanation of the input/output parameters follows:
T/V : Wall time / encoded variant.
N : The order of the coefficient matrix A.
NB : The partitioning blocking factor.
P : The number of process rows.
Q : The number of process columns.
Time : Time in seconds to solve the linear system.
Gflops : Rate of execution for solving the linear system.
The following parameter values will be used:
N : 8000
NB : 256
PMAP : Row-major process mapping
P : 1
Q : 1
PFACT : Left
NBMIN : 2
NDIV : 2
RFACT : Right
BCAST : 2ring
DEPTH : 0
SWAP : Mix (threshold = 64)
L1 : transposed form
U : transposed form
EQUIL : yes
ALIGN : 8 double precision words
- The matrix A is randomly generated for each test.
- The following scaled residual check will be computed:
||Ax-b||_oo / ( eps * ( || x ||_oo * || A ||_oo + || b ||_oo ) * N )
- The relative machine precision (eps) is taken to be 1.110223e-16
- Computational tests pass if scaled residuals are less than 16.0
T/V N NB P Q Time Gflops
WR02R2L2 8000 256 1 1 51.27 6.660e+00
HPL_pdgesv() start time Sun Apr 24 09:13:21 2016
HPL_pdgesv() end time Sun Apr 24 09:14:12 2016
||Ax-b||_oo/(eps*(||A||_oo*||x||_oo+||b||_oo)*N)= 0.0025941 ...... PASSED
Finished 1 tests with the following results:
1 tests completed and passed residual checks,
0 tests completed and failed residual checks,
0 tests skipped because of illegal input values.
End of Tests.
N : 8000
NB : 256
P : 1
Q : 1
PFACT : Left
NBMIN : 2
NDIV : 2
RFACT : Right
BCAST : 2ring
DEPTH : 0
U : transposed form
EQUIL : yes
WR02R2L2 8000 256 1 1 51.47 6.634e+00
HPL_pdgesv() start time Sun Apr 24 09:14:53 2016
HPL_pdgesv() end time Sun Apr 24 09:15:44 2016
End of Tests.
N : 8000
NB : 256
P : 1
Q : 1
PFACT : Left
NBMIN : 2
NDIV : 2
RFACT : Right
BCAST : 2ring
DEPTH : 0
U : transposed form
EQUIL : yes
WR02R2L2 8000 256 1 1 51.69 6.605e+00
HPL_pdgesv() start time Sun Apr 24 09:16:14 2016
HPL_pdgesv() end time Sun Apr 24 09:17:06 2016
End of Tests.You "tested" your 'extreme', (most likely unstable overclock), by "watching a 30 min HD youtube video", huh?sprengerle wrote:So that could be that my pi is stable with 1380mHz . because I tested it with a HD Youtube Video an that was during half an hour and at the end i only got 58°C
so you can Test your pi yourself and when it works stable, it's ok
You can't. But a mod might, if they think it is neccessary.sprengerle wrote:how can I delete a Topic![]()
No. You should not 'freeze' at all. The test takes around 1-2 min or so to complete (see screenshot). Sounds like you may have crashed as a result of an unstable overclock (my guess is over_voltage, or arm_freq is too high, or gpu_mem is too high (set gpu memory allocation to 48 for optimal results)).sprengerle wrote:is it normal that my screen freeces when running ./xhpl ?
since 10 minutes
