davenull
SD full format fails but not Quickformat
Sat Apr 30, 2016 4:34 pm
hello,
is that a known issue?
SD Quickformat works,
but SD full format fails both by Windows format and by SDFormatter: in both cases the formatting stops after a few sectors
SD SDFormatter format error.jpg (10.6 KiB) Viewed 2105 times
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
davenull
Re: SD full format fails but not Quickformat
Sat Apr 30, 2016 4:35 pm
the Windows format error screen shot:
SD Windows format error.jpg (6.77 KiB) Viewed 2102 times
ps,
it's a 32GB microSD (by Intenso)
davenull
Sun May 01, 2016 6:51 am
no explanations or even similar experiences? Why can the full format fail?
Anyway, a
chkdsk H: /F /R
shows no mistakes after Quick Format.
Does that mean that the SD card ist defective nevertheless?
Sun May 01, 2016 9:38 am
davenull wrote:no explanations or even similar experiences? Why can the full format fail?
1. Damaged SDCard
2. Fake SDCard
3. Lifetime expired SDCard
4. USB reader that's incompatible with SDHC or SDXC
5. Software failure.
I've replaced the Win32DiskImager with the special version that includes RPi features from viewtopic.php?f=62&t=129848
davenull
Sun May 01, 2016 10:08 am
the USB SD reader was built-in into my Windows PC (5 years old), so I actually doubt that it's incompatible (CMIIW).
the card is new, and files can be stored on it, so it can't be completely damaged or a fake IMO.
Although the card is new, there may be some defective sectors on it, agreed - but why does chkdsk find nothing then?
(I'll try your new Win32DiskImager ASAP - and try formatting with it anew...)
DirkS
Sun May 01, 2016 10:26 am
davenull wrote:the USB SD reader was built-in into my Windows PC (5 years old), so I actually doubt that it's incompatible (CMIIW).
A lot of older rreaders cannot handle the newer SD cards.
SD cards are not just 'dumb' memory chips. There's a microcontroller in there that interfaces with the computer.
On fake cards they give out false information about the size. They will accept write commands and say it succeeded but the output has gone to /dev/null
The best way of finding out if the card is damaged / fake is to write to every byte using a unique pattern and then read it back.
For Windows you can use h2testw (http://www.heise.de/download/h2testw.html)
ghans
Sun May 01, 2016 10:45 am
I myself also mistrust inbuilt SD card readers.
Use f3probe for a quick test , H2testw or f3 are very slow
but very (too ?) thorough.
ghans
davenull
Sun May 01, 2016 11:09 am
ok, thank you, I will do so and report!
davenull
Sun May 01, 2016 11:35 am
error:
PiWin32diskImager could not be started because QT5core.dll is missing
what is this kind of file
davenull
Sun May 01, 2016 11:38 am
H2testW:
Fehler beim Schreiben der Datei 'H:\1.h2w', Offset 0x14e00000.
Bis hierher geschriebene Testdaten können trotzdem geprüft werden.
(Das System kann die angegebene Datei nicht finden. Code 2)
Schreibrate: 10,4 MByte/s
H2testw v1.4
now what does that mean or express?
DirkS
Sun May 01, 2016 11:41 am
davenull wrote:H2testW:
H2testw v1.4
It's a write error :roll:
This either means that you have a faulty SD card or there's a problem with the SD card reader.
davenull
Sun May 01, 2016 11:50 am
ok, I now tried another (older) 32GB SD card then with format and H2testW.
With this card I got also full format errors (Windows and SDFormatter),
and with H2testw I got a write error at another Offset.
Fehler beim Schreiben der Datei 'H:\3.h2w', Offset 0x35100000.
Achtung: Nur 29651 von 29652 MByte getestet.
Schreibrate: 12,7 MByte/s
H2testw v1.4
Now: both SD cards damaged?
Or SD reader defective?
DirkS
Sun May 01, 2016 11:55 am
Most likely a reader problem. Get a new USB reader.
Here in the UK we can get them at Poundland for... wait for it... £1
And I got one off ebay for 99p :D
davenull
Sun May 01, 2016 12:03 pm
ok, I'll order a new one - from Euroland ;)
(I already ordered one shortly from Yuanland, but it's a long time for shipping here... :( )
Return to “Beginners”
